.NET
Getting the Attach Images file details
3 REPLIES 3
RamanSBV
521 Views, 3 Replies
Please guide me
For retrieving information about attach DWG file there is a API call "db.GetHostDwgXrefGraph(true)"
Similarly is there any API call for Attach Image files
Raman
3 REPLIES 3
philippe.leefsma
in reply to: RamanSBV
Hi There,
You can use the static API "RasterImageDef.GetImageDictionary".
This will return the id of the RasterImage dictionary. Iterating through its record will give you access to the "RasterImageDef" objects.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Hallex
Here is a code I've found in my code library,
change it to your needs:
        [CommandMethod("ImageName")]
        public void GetImageFileName()
            Document doc=Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed= doc.Editor;
            ErrorStatus es = new ErrorStatus();
              try
                    using (Transaction tr = db.TransactionManager.StartTransaction())
                        ObjectId imageDictId = RasterImageDef.GetImageDictionary(db);
                        DBDictionary imageDict = tr.GetObject(imageDictId, OpenMode.ForRead) as DBDictionary;
                        ObjectId rasterId = ed.GetEntity("\nSelect an image: ").ObjectId;
                        RasterImage image = tr.GetObject(rasterId, OpenMode.ForRead) as RasterImage;
                        ObjectId imageDefId = imageDict.GetAt(image.Name);
                        RasterImageDef imageDef = tr.GetObject(imageDefId, OpenMode.ForWrite) as RasterImageDef;
                        string filename = imageDef.ActiveFileName;
                        Application.ShowAlertDialog(filename);
                        tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage
                    (ex.Message + "\n" + ex.StackTrace);
            finally
                ed.WriteMessage("\n{0}", es.ToString());
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
kbarnettza
in reply to: Hallex
J ... How do you do this same process using interop/COM ?
Thx.
Kevin.
”Boost
