.NET
Active Contributor
WWFreeman
Message 1 of 3 (318 Views)
Getting minimal polygon that contains given point
318 Views, 2 Replies
11-09-2012 10:50 AM
Hello again. This time I would like to have chat about a problem that resembles to what the hatch command is doing.
I am about to implement an algorithm that takes a point and gives minimal polygon that contains it. (or null, be there no such polygon)
Observing the hatch command, one would think there is already functionality that covers this. But I fail to get on its track.To materialize the question: does someone know whether the functioanlity is expsed and where to find it? In case there is such a thing yet, I would not mind elaborating the solution here. Thanks!
Valued Mentor
gasty1001
Message 2 of 3 (289 Views)
Re: Getting minimal polygon that contains given point
11-09-2012 04:07 PM in reply to: WWFreeman
Check the TraceBoundary method of the editor class.
Gaston Nunez
Active Contributor
WWFreeman
Message 3 of 3 (281 Views)
11-09-2012 09:51 PM in reply to: gasty1001
Yay, that was fast, and does work. Articles on the topic can be found once one knows how the feature is called.
There is an example of getting the traced boundaires with isles, and drawing them back:
http://through-the-interface.typepad.com/through_the_interface/2010/06/tracing-a-boundary-defined-by...
Just one more related question: is there a way to trace a boundary on a specified layer? So far I figure it is possible to turn off all unwanted layers and restore their visibility back as soon as the boundary has been traced. Is that the only solution?
You are not logged in.
Ask the Community
