• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    RamanSBV
    Getting autocad application details
    197 Views, 7 Replies
    05-16-2012 11:44 PM
    Could you please any one help me on below issue.
    How i can retrieve the autocad application details like autocad file type like ( drawing file or dwt file) and file extension of active open autocad file using c#.
    Raman
    Please use plain text.
    Hallex
    Re: Getting autocad application details
    05-17-2012 12:39 AM in reply to: RamanSBV
    Check FileInfo property, e.g.:
            using System.IO;
            [CommandMethod("cfile")]
            public static void CheckExtension()
                FileInfo fi = new FileInfo(@"C:\Test\MyFile.dwg");
                if (fi.Exists)
                    MessageBox.Show(fi.Extension);
    ~'J'~
    Valued Contributor
    RamanSBV
    05-17-2012 12:45 AM in reply to: RamanSBV
    yes, in this way we can get the file info.
    But I need to get the autocad active file details , like type (dwg or dwt) of the autocad file either it is saved or not. and application name like (Autocad drawing file) or (Autocad template file)
    using autocad APIs
    Raman
    05-17-2012 05:51 AM in reply to: RamanSBV
    You find all properties of the current open file under this object:
    Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
    There you have all "Document"-based infos and on hierarchie deeper:
    Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database
    you have all "Database"-relevant info (also .Filename for knowing about DWT or DWG)
    Is there anything missing then?
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    RamanSBV
    05-17-2012 10:12 PM in reply to: alfred.neswadba
    Thanks for your post this issue.
    But I am unable to get the details as you mentioned. Could you please help on this.
    Raman
    05-17-2012 11:28 PM in reply to: RamanSBV
    At the moment I don't know what details you are looking for, what is "the details" for you? The only one you mentioned (I understood) is you want to know if a DWT or a DWG is opened.
    For that check the extension (last three characters) of:
    Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.FileName
    If you need any other properties (and you don't find them by Intellisense under the two statements in my previous post) then let us know what properties (exactly) you look for.
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    RamanSBV
    05-17-2012 11:47 PM in reply to: alfred.neswadba
    Thanks for your quick reply...
    Apart from this file type, i would like to know what is the application name. like "autocad drawing" file.
    why I need this data from application is same addin is going to install in inventor and micro station.
    So, i need to show application type.
    I think, you got my point.
    Raman
    05-17-2012 11:57 PM in reply to: RamanSBV
    Sorry, not any word, as I don't know how an application name could be "AutoCAD Drawing" or "AutoCAD Drawing File".
    If you think about the caption of the application-window, then the property is called "Caption".
    - alfred -
    Alfred NESWADBA
