.NET
.NET
Valued Contributor
dynamicscope
Message 1 of 6 (1,139 Views)
Getting an intersecting point coordinate of two polylines(lines)
1139 Views, 5 Replies
07-12-2012 12:24 AM
Hi, I wonder if there is a way to get an intersecting point coordinate of two polylines(lines) programmatically.
For example, like in the below sample picture, I need to get coordinates of the points in the red cycles.
Is there any method that I can easily use?
Could I get a sample code snippet that computes the coordinates? (in C# & ObjectARX 2010 if possible?)
I've looked up "Through the Interface" and this disscussion group. couldn't find any useful yet.
Please someone help me. =(
Thank you for your time.
Jake
Hallex
Message 2 of 6 (1,133 Views)
Re: Getting an intersecting point coordinate of two polylines(lines)
07-12-2012 12:57 AM in reply to: dynamicscope
Check this out
        [CommandMethod("checkinters")]
        public void CheckInterference()
            Database db = HostApplicationServices.WorkingDatabase;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
                Transaction tr = db.TransactionManager.StartTransaction();
                using (tr)
                    try
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                        PromptEntityOptions peo = new PromptEntityOptions("\nSelect a first polyline  >>");
                        peo.SetRejectMessage("\nSelected object might be of type polyline only >>");
                        peo.AddAllowedClass(typeof(Polyline), false);
                        PromptEntityResult res;
                        res = ed.GetEntity(peo);
                        if (res.Status != PromptStatus.OK)
                            return;
                        Entity ent = (Entity)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                        if (ent == null)
                            return;
                        Polyline poly = (Polyline)ent as Polyline;
                        peo = new PromptEntityOptions("\nSelect second polyline  >>");
                            return;
                        if (ent == null)
                            return;
                        Polyline poly2 = (Polyline)ent as Polyline;
                        Point3dCollection pts = new Point3dCollection();
                        poly.IntersectWith(poly2, Intersect.OnBothOperands, pts, (int)IntPtr.Zero, (int)IntPtr.Zero);
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(string.Format("Hint:\nNumber of Verices: {0}\nNumber of Intersections: {1}", poly.NumberOfVertices, pts.Count));
                     // test for visulization only
                        foreach (Point3d pt in pts)
                            Circle circ = new Circle(pt,Vector3d.ZAxis,10 * db.Dimtxt);
                            circ.ColorIndex = 1;
                            btr.AppendEntity(circ);
                            tr.AddNewlyCreatedDBObject(circ, true);
                        tr.Commit();
                    catch (System.Exception ex)
                        ed.WriteMessage("\n{0}\n{1}", ex.Message, ex.StackTrace);
~'J'~
Hallex
Message 3 of 6 (1,130 Views)
07-12-2012 01:06 AM in reply to: dynamicscope
Can you upload the piece of this drawing
for testing?
~'J'~
Valued Contributor
dynamicscope
Message 4 of 6 (1,087 Views)
07-16-2012 10:34 PM in reply to: Hallex
It does work!! Thank you!! =)
Hallex
Message 5 of 6 (1,083 Views)
07-16-2012 11:38 PM in reply to: dynamicscope
You're welcome
Happy coding :smileyhappy:
~'J'~
New Member
applie_3
Message 6 of 6 (817 Views)
12-14-2012 11:16 PM in reply to: dynamicscope
Hi, i need to get coordinates of an image in autocad for my final year project. I am a student of computer engineering so dont have autocad background. Any help will highly be appriciated, thankyou.
