As stated in topic, I'm struggling with accessing multiple AutoCAD 2007 instances via COM. I have tried retrieving objects from ROT using monikers, but only succeeded in getting AcadDocument objects only. Is there a reliable way to achieve my goal?
Thanks in advance,
Vladimir Trifonov.
when you say specific instances, you mean ones created by you?
Thank you for reply.
Instances I want to access were created by a user. It's important to note that they are all refer to the same AutoCAD version (r17). When I use the original code from this thread, I'm able to get separate COM objects that respond to AcadApplication interface, but it turns out they all refer to a single instance.
