Getattribute problem
Message 1 of 8
I have a big problem to obtain the attribute linked to a block reference:
//CODE
AcadDocuments objAcadDocs = objAcadApp.Documents;
AcadDocument objAcadDoc = objAcadDocs.Open(filePath, true, "");
AcadBlocks objAcadBlks = objAcadDoc.Blocks;
foreach (AcadEntity objAcadEnty in objAcadDoc.ModelSpace)
if (objAcadEnty is AcadBlockReference)
AcadBlockReference objAcadBlkRef = (AcadBlockReference)objAcadEnty;
if (objAcadBlkRef.HasAttributes == true)
AcadAttributeReference objAcadAttRef = (AcadAttributeReferenceClass)objAcadBlkRef.GetAttributes();
I'm using VS2005 with Autocad2004 (ActiveX API).
Thank for help
/Stefano
Replies (7)
Message 2 of 8
norman.yuan
COM method AcadBlockReference.GetAttributes() returns an array of AcadAttributeReference, not a single AcadAttributeReference. This is why your doe is not working: you are trying to cast an array of AcadAttributeReference to a single AcadAttributeReference
Norman Yuan
Drive CAD With Code
Message 3 of 8
norman.yuan,
how can I cast the array from AcadBlockReference.GetAttributes() to an array of AcadAttributeReference?
I've tried a lot but without success: can you provide me the code?
Thank you for your help, I'm desperate!
/Stefano
Message 4 of 8
It could be like this:
    if
(objAcadBlkRef.HasAttributes)
        //Loop
through the attributs
        foreach
(AcadAttributeReference att as AcadAttributeReference in
objAcadBlkRef.GetAttributs())
    switch (att.TagString.ToUpper())
        case "TAG1":
            break;
        case "TAG2"
            break;
Or
    if
        //Loop
        foreach
(object obj in objAcadBlkRef.GetAttributs())
AcadAttributeReference att=(AcadAttributeReference) obj;
        case "TAG1":
            break;
        case "TAG2"
    break;
Or
    if
        object[]
objs=objAcadBlkRef.GetAttributes();
        foreach (object obj in objs)
AcadAttributeReference att=(AcadAttributeReference)obj;
norman.yuan,
of AcadAttributeReference? I've tried a lot but without success: can you
provide me the code? Thank you for your help, I'm desperate!
/Stefano
Message 5 of 8
Sorry Norman Yuan,
it still doesn't work.
Example n°1:
Syntax error
Example n°2:
I receive error --> foreach statement cannot operate on variables of type 'object' because 'object' does not contain a public definition for 'GetEnumerator'
Example n°3 :
I receive error --> Cannot implicitly convert type 'object' to 'object[]'. An explicit conversion exists (are you missing a cast?)
It's like method GetAttributes return a single object, not an Array
Probably I'm confused about Autocad 2004 Object Model...
Thank you again!!
Message 6 of 8
Try:
{code}
object[] attributes = (object[]) blockrefObj.GetAttributes()
foreach( AcadAttributeReference att in attributes )
{code}
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6191850@discussion.autodesk.com...
Sorry Norman Yuan, it still doesn't work. Example n°1: Syntax error Example
n°2: I receive error --> foreach statement cannot operate on variables of
'GetEnumerator' Example n°3 : I receive error --> Cannot implicitly convert
a cast?) It's like method GetAttributes return a single object, not an Array
Probably I'm confused about Autocad 2004 Object Model... Thank you again!!
Message 7 of 8
IT WORKS!!!
Thank you Tony, thank you Norman Yuan!!
Message 8 of 8
edson_luiz86
Sorry for post on old post, but I've tried to conveting the object array of .GetAttributes() for a many ways yestarday without succes. Today this post help me so much tanks.
