• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    GetString with Keywords FATAL ERROR
    276 Views, 10 Replies
    03-16-2012 02:43 AM
    i encountered a problem, when I try to use GetString with Keywords
    Dim optString As New PromptStringOptions("Zadaj nazov: ")
    optString.Keywords.Add("Vypisat")
    Dim resPrompt As PromptResult = ed.GetString(optString)
    AutoCAD crashes with FATAL ERROR on the last line.
    Please use plain text.
    Valued Contributor
    Re: GetString with Keywords FATAL ERROR
    03-16-2012 03:50 AM in reply to: matus.brlit
    You need to use PromptKeywordOptions like this:
                Dim optstring As New PromptKeywordOptions("Zadaj nazov: ")
                optstring.Keywords.Add("Vypisat")
                Dim resPrompt As PromptResult = ed.GetKeywords(optstring)
     Hope that helps.
    Hallex
    03-16-2012 03:52 AM in reply to: matus.brlit
    You can't add keywords to Getstring method
    But you might be want to use DefaultValue property
    to get possibility for empty input
    And also you always use Try.. Catch statement to
    save your working time :smileyhappy:
    See sample:
            Public Sub testkwords()
                Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                Dim db As Database = doc.Database
                Dim ed As Editor = doc.Editor
                Try
                    optString.UseDefaultValue = True
                    optString.AppendKeywordsToMessage = True
                    optString.DefaultValue = "Vypisat"
                    If resPrompt.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim strRes As String = resPrompt.StringResult
                    MsgBox(strRes)
                Catch ex As System.Exception
                    MsgBox(ex.Message + vbCrLf + ex.StackTrace)
                Finally
                End Try
            End Sub
    ~'J'~
    03-16-2012 04:10 AM in reply to: matus.brlit
    to Paulio: keyword prompt only allows to enter keyword, i want an user inputed string, or a keyword
    to Hallex: Thanks for the workaround. That's strange, that PromptStringOptions has a Property Keywords and then throws an exception saying Keywords are not allowed.
    I think that I will have to stick with this, but it's strange to have a Keyword in <> instead of [], very odd behavior. Whay if I wanted to have more than one keyword?
    Hallex
    03-16-2012 07:36 AM in reply to: matus.brlit
    If you need to add more than one keyword
    you have to use ed.getkword method, see examples,
    hope you will be undrerstand how to use this functions,
    feel free to adopt them to your needs:
            Function PromptKeyWords(ByVal PromptStr As String, ByVal kwords As String(), ByVal deflt As String) As Boolean
                Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
                Dim prOpt As PromptKeywordOptions = New PromptKeywordOptions(PromptStr)
                Dim prRes As PromptResult = Nothing
                prOpt.AppendKeywordsToMessage = True
                For Each wd As String In kwords
                    prOpt.Keywords.Add(wd)
                Next
                prOpt.Keywords.Default = deflt
                prOpt.SetMessageAndKeywords(PromptStr, "[Yes/No]")
                prOpt.Keywords.Add("[")
                prRes = ed.GetKeywords(prOpt)
                If prRes.Status = PromptStatus.Cancel Then
                    MsgBox("Error: user cancelled")
                    Return False
                Else
                    MsgBox(prRes.StringResult)
                    Return True
                End If
            End Function
            Public Shared Function GetKwordOut(ByVal ed As Editor, ByVal msg As String, ByVal kwords As String()) As String
                Dim pko As New PromptKeywordOptions(vbLf + msg)
                pko.AllowNone = True
                For Each itm As String In kwords
                    pko.Keywords.Add(itm)
                Next
                pko.Keywords.Default = kwords.GetValue(kwords.Length - 1).ToString()
                Dim pkr As PromptResult = ed.GetKeywords(pko)
                If pkr.Status <> PromptStatus.OK Then
                    Return String.Empty
                Else
                    Return pkr.StringResult
                End If
            End Function
    ~'J'~
    03-19-2012 12:01 AM in reply to: Hallex
    Hallex, you didn't understand what I meat.
    I want a string prompt, i want user to be able to enter a string, any string and also be able to choose a keyword for some action. But I guess it's not possible.
    Hallex
    03-19-2012 01:46 AM in reply to: matus.brlit
    Sorry, Matus
    I have disagreed completely
    You didn't understand how to use the function I posted
    Please, try complete solution:
           <CommandMethod("MatusBrilt", "matus", CommandFlags.Modal)> _
        Public Sub SampleTest()
            Dim kwords As String() = {"Rectangle", "Circle", "Ellipse", "Squiggle"}
            Dim strout As String = GetKwordOut(ed, vbLf + "Choose a Shape Type or Enter Another Type You Want: ", kwords)
            ed.WriteMessage(vbLf + "{0}", strout)
        End Sub
            pko.AllowArbitraryInput = True
            Next
                Return String.Empty
            Else
            End If
        End Function
    ~'J'~
    03-19-2012 01:57 AM in reply to: Hallex
    If I enter anything else in the eg.GetKeywords prompt, I get an error "Invalid option keyword." and I am prompted again.
    I use AutoCAD 2012.
    Hallex
    03-19-2012 02:41 AM in reply to: matus.brlit
    You have to copy code I posted in the last post because I've added
    ArbitaryInput=True in this function
    Then it will be work as you need, see what I have a got after running the code
    (tested on 2010th) :
    Command: MATUS Choose a Shape Type or Enter Another Type You Want [Rectangle/Circle/Ellipse/Squiggle] <Squiggle>: Trapezoid
     Trapezoid
     Command:
    ~'J'~
    03-19-2012 03:24 AM in reply to: Hallex
    oh, finally :smileyhappy:
    thank you very much, I missed that one
