GetBlockReferenceIds Problems
HJohn1
Message 1 of 9
HJohn1
I am trying to call the BlockTableRecord GetBlockRefenceIds function to get a list of all BlockRefences on that a Layout, but not matter what I try it always returns 0.  Here is what my test looks like:  A drawing with two PaperSpace layouts each with a few BlockReferences, in addtion some more BlockReferences are in the ModelSapce.  Here is my code:
 db = HostApplicationServices.WorkingDatabase
 blt = CType(Tran.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
 btr = CType(Tran.GetObject(db.CurrentSpaceId, OpenMode.ForRead), BlockTableRecord)
 IdList = btr.GetBlockReferenceIds(True, True)
 If IdList.Count > 0 Then
    Stop
 I am setting the current layout before executing the code.  It does not matter if I change it and instead of using "db.CurrentSpaceId" I use "blt(BlockTableRecord.ModelSpace) or .PaperSpace.  This function always returns 0.  Please help before I go nuts.
Replies (8)
Message 2 of 9
HJohn1
Here is a bit more info about my post.  The reason I need to do this is to get the newest BlockReference in the Layout.  There could be any number of them, but I am interested only on the last one added to the Layout.  In VBA I would do something like the code shown below to get the last BlockRef added to the Layout.  Hope this helps to understand what I am doing and perhaps to get better help.  TIA
Public Function GetNewestBlock(ByVal bname As String) As AcadBlockReference
Dim b As AcadBlockReference
Dim blayout As AcadBlock
Dim i As Integer
Dim e As AcadEntity
Set blayout = ThisDrawing.ActiveLayout.Block
For i = blayout.Count - 1 To 0 Step -1
    Set e = blayout.Item(i)
    If TypeOf e Is AcadBlockReference Then
        Set b = e
        If b.Name = bname Then
        Set GetNewestBlock = b
        Exit For
Next i
End Function
Message 3 of 9
_gile
The BlockTableRecord.GetBlockRefenceIds methods Returns a list of BlockReferences that reference this BlockTableRecord.
The way you use it, you're trying to ge the ModelSpace references in the drawaing...
Use a filtered selection set instead :
TypedValue[] filter = new TypedValue[2] {new TypedValue(0, "INSERT"), new TypedValue(410, "model")};
PromptSelectionResult psr = ed.GetSelection(new SelectionFilter(filter));
if (psr.Status != PromptStatus.OK) return;
Gilles Chanteau
GileCAD
GitHub
Message 4 of 9
_gile
You can do it the same way as you did in VBA:
- step through the space BlockTableRecord
- get the entities from ObjectIds
- evaluate if it's a BlockReference and if so set the variable...
Or, using the SelectionSet way and comparing the BlockReferences Handles (the greatest is the newest).
Gilles Chanteau
GileCAD
GitHub
Message 5 of 9
HJohn1
_gile
Thank you very much and again and again.  I was not aware that one could use the code 410 in SelectionSets.  Up to very recently I was using AC2007 VBA and code 410 was not allowed in SelectionSets.  This opens up to a whole new approach.
Message 6 of 9
wang890
hey guys
just thought i expand the problem here instead of posting a new one since this is similar.
i am trying to insert all the blocks in an empty drawing which there is nothing inserted just in the dwg memory.
i do the same thing and it gives me 0 blocks.
i am trying to insert each block into modelspace without asking which block. i'll do the coordinate calculation. this is for creating a table of blocks. but there are so many blocks and i don't want to insert one by one.
Public
SubInsertBlock()
Dim db AsDatabase = HostApplicationServices.WorkingDatabase()
Dim id AsObjectId
Using trans AsTransaction = db.TransactionManager.StartTransaction()
TryDim bt AsBlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForWrite)
Dim btr AsBlockTableRecord = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
Dim ed AsEditor = Application.DocumentManager.MdiActiveDocument.Editor
Dim oBlock AsBlockReference
Dim y AsDoubleForEach id In btr.GetBlockReferenceIds(False, False)
Dim oAcadEntity AsEntity = trans.GetObject(id, OpenMode.ForWrite)
IfTypeOf (oAcadEntity) Is BlockReference Then'get block object, check each block
oBlock =
CType(oAcadEntity, BlockReference)
If oBlock.Name <> "_None"ThenDim oPoint3D AsNewPoint3d(0, y, 0)
Dim insert AsNewBlockReference(oPoint3D, oBlock.Id)
trans.AddNewlyCreatedDBObject(insert,
True)
y -= 10
EndIfEndIfNext
trans.Commit()
Catch ex AsException
MsgBox(
"Error: "+ ex.Message)
EndTryEndUsingEndSub
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
Message 7 of 9
jeff
Does the empty drawing contain the blocks(definitions)?
In a empty there will be no blockreferences you need to create them, kind of like you did but skip the GetBlockReferenceIds part and just use BlockTablesRecord Id and check if layout, since it is empty I am guessing no anonymous and xref's etc....................
and GetBlockReferenceIds(false, false)------having the first argument set to false will only return nested block references.
You can also find your answers @ TheSwamp
Message 8 of 9
jeff
Here is a example and see how it itereates the blocktable using the definitions which are BlockTableRecords.
 <CommandMethod("InsertAllBlocks")> _
        Public Sub InsertAllBlocks()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using trx As Transaction = db.TransactionManager.StartTransaction()
                Dim bt As BlockTable = trx.GetObject(db.BlockTableId, OpenMode.ForRead)
                Dim modelBtr As BlockTableRecord = trx.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                Dim Xval As Double = 0
                Dim Yval As Double = 100
                Dim counter As Integer = 0
                For Each objId As ObjectId In bt
                    Dim btr As BlockTableRecord = trx.GetObject(objId, OpenMode.ForRead)
                    If btr.IsLayout Then
                        Continue For
                    Dim bref As New BlockReference(New Point3d(Xval, Yval, 0), objId)
                    modelBtr.AppendEntity(bref)
                    trx.AddNewlyCreatedDBObject(bref, True)
                    If Not counter = 10 Then
                        counter += 1
                        Xval += 10
                    Else
                        counter = 0
                        Xval = 0
                        Yval -= 10
                Next
                trx.Commit()
            End Using
        End Sub
Message 9 of 9
wang890
good morning Jeff:
this thing work awesome.
thank you very much and have a nice weekend.
Stantec
