.NET
Active Member
hbjadeja
Message 1 of 3 (306 Views)
Get xREF Detail without Opening AutoCAD using Console/Windows Application
306 Views, 2 Replies
12-10-2012 10:06 PM
I have made a plug-In for AutoCAD 2013 which reads the x-Ref from a DWG File.
However, I wants to read this xRef Details (with parent child tree information), from an Console or Windows Form Based Application. i.e. without loading DWG in AutoCAD, Is it possible to directly read the xRef details without Opening AutoCAD??
Kindly help on this ASAP.
Thank you in advance.
Hardik
Active Member
hbjadeja
Message 2 of 3 (274 Views)
Re: Get xREF Detail without Opening AutoCAD using Console/Windows Application
12-12-2012 01:48 AM in reply to: hbjadeja
I have found that using RealDWG SDK, it is possible to read the dwg file without opening the file.
I am not able to download SDK of the same....its a licence version only, no trail version is available.
So anyone can help from where can I get the trail version of RealDWG or any other alternative similar to RealDWG is avialable or not
Thanxs
ADN Support Specialist
Virupaksha.aithal
Message 3 of 3 (252 Views)
12-16-2012 10:39 PM in reply to: hbjadeja
Please refer http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=770257 for details on RealDWG. This page also contains the details on procedure to get the license for RealDWG.
 FYI, from AutoCAD 2013, you can use command line version of AutoCAD. Please refer blog http://adndevblog.typepad.com/autocad/2012/04/getting-started-with-accoreconsole.html . (it needs AutoCAD to be installed in the system)
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Ask the Community
