.NET
Get the string value of MText.Content
8 REPLIES 8
Message 1 of 9
1480 Views, 8 Replies
when I got the string value of a MText,it contains TextStyle information such as font、bold、italic and so.Then how can I get the pure value of the MText.Content except the style information.I use C#.
Thanks in advance!
8 REPLIES 8
Message 2 of 9
Have a look here:
http://www.caddzone.com/MTextFragmentSample.cs
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5136968@discussion.autodesk.com...
Thanks in advance!
Message 3 of 9
It is a sample without any error checking:
[code]
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using App = Autodesk.AutoCAD.ApplicationServices.Application;
using EI = Autodesk.AutoCAD.EditorInput;
using ED = Autodesk.AutoCAD.EditorInput.Editor;
[assembly: CommandClass(typeof(ClassLibrary.Class))]
namespace ClassLibrary {
public class Class {
// Define Command "SplitMtext"
[CommandMethod("SplitMtext")]
static public void test() { // This method can have any name
ED ed = App.DocumentManager.MdiActiveDocument.Editor;
EI.PromptEntityResult rs = ed.GetEntity("\nSelect Mtext: ");
if (rs.Status == EI.PromptStatus.OK) {
ObjectId id = rs.ObjectId;
Database db = App.DocumentManager.MdiActiveDocument.Database;
Transaction trans = db.TransactionManager.StartTransaction();
Entity ent = (Entity)trans.GetObject(id, OpenMode.ForRead);
MText mt = ent as MText;
if (mt != null) {
DBObjectCollection dbs = new DBObjectCollection();
mt.Explode(dbs);
string s = "";
foreach (Entity en in dbs) {
DBText txt = en as DBText;
if (txt != null) {
s += txt.TextString;
ed.WriteMessage("\n" + s); // Print pure Mtext
} else {
ed.WriteMessage("\nIt is not MText entity!");
trans.Commit();
[/code]
Message 4 of 9
Thank you,Alexander,it really works very well.
Message 5 of 9
I think that solution by Tony is more universal and elegant, because in next versions of AutoCAD method explode may get text's in other order then now.
It is not documented trick!
Best Regard,
Alexander Rivilis.
Message 6 of 9
I think that Tony's site isn't anymore and therefore the 'better' solution is gone as well 😞
Message 7 of 9
kdub_nz
Perhaps this:
http://ltc0420.blog.sohu.com/30233215.html
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Message 8 of 9
in reply to: kdub_nz
Thanks! In the meantime I went with the explode solution as I needed the boundaries of the actual DBText object and not of the overall MText. An alternative is to use the .Text property combined with a Split.
Message 9 of 9
_gile
Have a look at the MText.Text property (this property didn't exist yet whrn this post started).
Gilles Chanteau
GileCAD
GitHub
”Boost
