.NET
Active Contributor
ditran
Message 1 of 3 (185 Views)
Get specified attribute from external block
185 Views, 2 Replies
03-21-2013 07:26 PM
Hi All,
How to get attributes from block located at external drawing?
Thanks for any helps.
Moderator
Alexander.Rivilis
Message 2 of 3 (156 Views)
Re: Get specified attribute from external block
03-21-2013 11:48 PM in reply to: ditran
ditran wrote:
Hi All,
Block - is a BlockTableRecord or a BlockReference?
Attribute - is a AttributeDefinition or a AttributeReference or some others?
Please use a "AutoCAD .NET API terminology"
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Hallex
Message 3 of 3 (123 Views)
03-24-2013 10:40 AM in reply to: ditran
Try this code tested on A2010,
change block name to your suit
        <CommandMethod("rad")> _
        Public Sub ReadAttributesToDataBase()
            Dim blockName As String = "TITLEBLOCK"
            Dim ofd As New Autodesk.AutoCAD.Windows.OpenFileDialog( _
             "Open source DWG for read", Nothing, "dwg", "", Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.DoNotTransferRemoteFiles)
            Dim dr As System.Windows.Forms.DialogResult = ofd.ShowDialog()
            If dr <> System.Windows.Forms.DialogResult.OK Then Return
            Dim sourcedwg As String = ofd.Filename
            Dim dict As New Dictionary(Of String, String)
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument()
            Dim doclock As DocumentLock = doc.LockDocument()
            Dim ed As Editor = doc.Editor
            Dim db As Database = doc.Database
            Using doclock
                Using exdb As New Database(False, True)
                    exdb.ReadDwgFile(sourcedwg, System.IO.FileShare.ReadWrite, True, "")
                    Using extr As Transaction = exdb.TransactionManager.StartTransaction()
                        Dim exbt As BlockTable = DirectCast(extr.GetObject(exdb.BlockTableId, OpenMode.ForRead), BlockTable)
                        If exbt.Has(blockName) Then
                            Dim id As ObjectId = exbt(blockName)
                            Dim exbtr As BlockTableRecord = extr.GetObject(id, OpenMode.ForRead)
                            For Each brid As ObjectId In exbtr.GetBlockReferenceIds(True, True)
                                Dim exbref As BlockReference = extr.GetObject(brid, OpenMode.ForRead)
                                For Each attid In exbref.AttributeCollection
                                    Dim attref As AttributeReference = extr.GetObject(attid, OpenMode.ForRead)
                                    If Not dict.ContainsKey(attref.Tag) Then
                                        dict.Add(attref.Tag, attref.TextString)
                                    End If
                                Next
                            Next
                        End If
                        extr.Commit()
                    End Using
                End Using
            End Using
            'use returned values here:
            For Each Kvp As KeyValuePair(Of String, String) In dict
                ed.WriteMessage(vbLf + "Tag: {0}" + vbTab + "Value: {1}" + vbLf, Kvp.Key, Kvp.Value)
            Next
        End Sub
You are not logged in.
Ask the Community
