.NET
Get custom property value
1 REPLY 1
cadcamm99
766 Views, 1 Reply
I am using AutoCAD 2014 and VB.NET 2010.  I am trying to get the value of a custom property and cannot seem to do so.
The old command I used for AutoCAD 2010 was:
ThisDrawing.SummaryInfo.GetCustomByKey(strParameter, strValue)
But this does not work anymore. So I created this sub but it does not seem to work either.  Any clues to what I am doing wrong?
Public
Sub subFindCustomParam(ByVal strUserParameter AsString)
   Dim infoDB AsDatabase =Application.DocumentManager.MdiActiveDocument.Database
   Dim infoBuilder AsDatabaseSummaryInfoBuilder = NewDatabaseSummaryInfoBuilder(infoDB.SummaryInfo)
   Dim infodict AsDBDictionary = infoBuilder.CustomPropertyTable
   ForEach infoentry As DictionaryEntry In infodict
      If strUserParameter = infoentry.Key Then
                CurrentParameterValue = infoentry.Value
                   bolCustomPropertyFound =True
        Exit For
      EndIf
   Next
EndSub
1 REPLY 1
cadcamm99
in reply to: cadcamm99
I figured it out.  Dictionary should be iDictionary.
”Boost
