I need to open a drawing and read the block attributes and find a block with name "ABC" and attribute named "Text" in "ABC" block. for which i am using the below code which is working perfectly.
Try AcadApp = GetObject(, "AutoCAD.Application") Catch ex As Exception AcadApp = CreateObject("AutoCAD.Application") End Try AcadApp.Visible = True Try AcadDoc = AcadApp.Documents.Open(DWGName, True) RichTextBox1.AppendText(" - Opened File Successfully" & vbCrLf) Me.Refresh() Catch ex As Exception RichTextBox1.AppendText(" - Can not Open this Drawing" & vbCrLf) Me.Refresh() Exit Function End Try Dim Obj As Object For Each Obj In AcadDoc.ModelSpace If Obj.ObjectName = "AcDbBlockReference" Then RibbonLabel1.Text = "Find Block: " & Obj.Name Me.Refresh() ' Check for attributes. If Obj.HasAttributes Then Dim AttList As Object Me.Refresh() If Obj.Name.ToString.ToLower = "abc" Then ' Build a list of attributes for the current block. AttList = Obj.GetAttributes ' Cycle throught the list of attributes. For _i = LBound(AttList) To UBound(AttList) ' Check for the correct attribute tag. If AttList(_i).TagString = "Text" Then return AttList(_i).TextString.ToString End If Me.Refresh() End If Next End If End If End If Next Obj
But i want to know whether is there any way to get the block named "ABC" directly without looping through all the objects.
Thank you.
Yes, there are two possibilities if you work managed (DLL in AutoCAD) or of you work COM-based (because you control AutoCAD from an external EXE):
Managed:
Get the BlockTableRecord for Block "ABC"
then you have access to the function GetBlockReferenceIDs ==> that gives you the ObjectID's of all references of this block-definition
COM + SelectionSet
Create a SelectionSet with a filter
(0 . INSERT) to define it searches for a BlockReference
(2 . "ABC") to have the BlockName defined you look for
- alfred -
{code}
Try this 5-mintes solution
(Win7 A2009 .NETRFramework 3.5)
Public Class Form1
Dim DWGName As String = "C:\Test\WorkingDrawing.dwg"
Dim AcadApp
Dim AcadDoc
Dim oSsets
Dim oSset
Dim ftype(0 To 3) As Short
Dim fdata(0 To 3) As Object
Public Function DoYourWork() As Boolean
Dim bln As Boolean = False
Try
End Try
Try
Me.Refresh()
Me.Refresh()
bln = False
Return bln
Exit Function
End Try
Dim pfset As Object
pfset = AcadDoc.PickFirstSelectionSet
pfset.Clear()
ftype(0) = 0 : ftype(1) = 2 : ftype(2) = 66 : ftype(3) = 410
fdata(0) = "insert" : fdata(1) = "abc" : fdata(2) = 1 : fdata(3) = "Model"
Call pfset.Select(5, Nothing, Nothing, ftype, fdata)'<--5= acSelectionSetAll
MsgBox("Selected: " & pfset.Count.ToString)
Dim Obj As Object
Dim msg As String = ""
For Each Obj In pfset
Me.Refresh()
Me.Refresh()
'' Check for the correct attribute tag.
Return AttList(_i).TextString.ToString
Me.Refresh()
End If
Next
End If
End If
End If
Next Obj
Return True
End Function
Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
DoYourWork()
End Sub
End Class
{/code}
