A jig's sampler doesn't give you osnapped-to points,
because they're considered 'tentative' until the user
clicks the mouse button to pick the point.
If you want the osnapped-to point while the user is
dragging, you have to use the Editor's PointMonitor
event in conjunction with your jig.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6387205@discussion.autodesk.com...
I have a jig that I use to select an endpoint. But the jig will only return the
position of the mouse. If I snap to end point for example and click a little bit
from the endpoint I will not get the endpoint. What should I do?
{code}
' Sampler captures mouse movements while asking for a point
Dim jigOpts As JigPromptPointOptions = New JigPromptPointOptions(vbLf &
"Select endpoint:")
jigOpts.UserInputControls = UserInputControls.NullResponseAccepted
myPR = prompts.AcquirePoint(jigOpts)
If myPR.Value.IsEqualTo(BasePt) Then
Return SamplerStatus.NoChange
Else
BasePt = myPR.Value
Return SamplerStatus.OK
{code}
