.NET
Rob.O
Message 1 of 3 (327 Views)
Get Mleader Block Attributes
327 Views, 2 Replies
09-27-2011 03:16 PM
Hi all!
I need help reading the values from an Mleader object that contains a block.  I can get attributes from normal blocks with no problem, but I am struggling with this.
I can get all the way up to casting the attributes, but when I try getting the AttributeReference, the code crashes.  How do I get the AttributeReference from the AttributeDefinition?  As it is now, if I declare the AttributeDefinition, the values return as nothing.
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim acEd As Editor = DocumentManager.MdiActiveDocument.Editor
        '' Start a transaction
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Try
                Dim acBt As BlockTable = acDoc.Database.BlockTableId.GetObject(OpenMode.ForRead)
                Dim acBtrMs As BlockTableRecord = DirectCast(acBt(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForRead), BlockTableRecord)
                Dim myReinfVals As New List(Of String)
                Dim myReinfQtys As New List(Of String)
                 For Each objId As ObjectId In acBtrMs
                    Dim acMReinf As MLeader = TryCast(acTrans.GetObject(objId, OpenMode.ForRead), MLeader)
                    If acMReinf IsNot Nothing Then
                        Dim MleadStyle As MLeaderStyle = acTrans.GetObject(acMReinf.MLeaderStyle, OpenMode.ForRead)
                        Dim strMlStyle As String = MleadStyle.Name
                        If strMlStyle = "ECDT_ANO-Rebar" Then
                            If MleadStyle.ContentType = ContentType.BlockContent Then
                                Dim blkid As ObjectId = acBt("X$X_ANO-RebarID")
                                Dim blk As BlockTableRecord = CType(acTrans.GetObject(blkid, OpenMode.ForRead), BlockTableRecord)
                                    For Each attobjId As ObjectId In blk
                                    Dim acEnt As Entity = CType(acTrans.GetObject(attobjId, OpenMode.ForRead), Entity)
                                    	If TypeOf acEnt Is AttributeDefinition Then
                                       		Dim attDef As AttributeDefinition = DirectCast(acEnt, AttributeDefinition)
						Dim attRef As AttributeReference = DirectCast(acEnt, AttributeReference)   '' << Cannot cast as Attributereference or code crashes
					End If
                                    Next
			    End If
                        End If
                    End If
                Next
	    Catch ex As Autodesk.AutoCAD.Runtime.Exception
                MsgBox("An error has occured. Please contact you system administrator." & vbCr & vbCr & ex.Message & vbCr & ex.StackTrace)
            Finally
            End Try
            acTrans.Commit()
        End Using
Thanks for any advice!
Rob.O
Message 2 of 3 (323 Views)
Re: Get Mleader Block Attributes
09-27-2011 03:36 PM in reply to: Rob.O
Just an aside...
I am also not able to cast the objectid to a BlockReference (as I normally would for a regular block) without AutoCAD crashing.
Dim acBref As BlockReference = blkid.GetObject(OpenMode.ForRead)
 What am I missing?
Thanks!
chiefbraincloud
Message 3 of 3 (303 Views)
09-29-2011 02:12 PM in reply to: Rob.O
Open acMReinf.BlockContentId as a BlockReference, and access the AttributeReference's ObjectId's through the that BlockReferences AttributeCollection.
You are not logged in.
Ask the Community
