.NET
Get ActiveLayout object in 64bit OS
1 REPLY 1
masa10789
358 Views, 1 Reply
Hi all,
Has anyone else run into this same problem with AutoCAD 2012, where you can't get the ActiveLayout.Name property from a Windows 64bit OS? This code only seems to work in 32bit OS. Anyone know of another way to get ActiveLayout in 64bit?
In this example code,using the following namespace:
namespace Autodesk.AutoCAD
Code example, but does not work in 64bit OS:
AcadDocument acadDOC = (AcadDocument)(openedSheet.AcadDocument);
                if (acadDOC != null)
                    layoutName = acadDOC.ActiveLayout.Name;
Tags (3)
1 REPLY 1
Jeff_M
in reply to: masa10789
I am able to use this in Win7 x64 on C3D2010 (32 bit) and C3D2012(64 bit).
”Boost
