First .net Program
First .net Program
Amremad
First .net Program
Amremad
Hi all
i donwload  ObjectARX 2011
and load ocx and dll to .net (VS2012)
and i created the class project and wite in it
'Contains the AutoCAD Type Library
Imports Autodesk.AutoCAD.Interop
'Contain the AutoCAD/ObjectDBX Type Library
Imports Autodesk.AutoCAD.Interop.Common
Public Class AdskCommand
    Public ReadOnly Property ThisDawing As AcadDocument
        Get
            Return Autodesk.AutoCAD. _
                ApplicationServices.Application. _
                DocumentManager.MdiActiveDocument. _
                AcadDocument
        End Get
    End Property
    <Autodesk.AutoCAD.Runtime.CommandMethod("myroutine")> _
    Public Sub myRoutine()
        ThisDawing.Utility.Prompt("Hello World From .Net")
    End Sub
End Class
 and no problem with compiling or save file in vs2012
 and i loaded it in CAD2010 or CAD 2013 using netload command
and when i write myRoutine in command bar . not run .. why
Try using .net Frameworks 4.0 and 3.5.
arcticad
You don't need to install the ObjectARX files for your project if your programming c# or VB
ObjectARX is for c++ Programming.
You also don't need to use COM Autocad.interop and you should start with a .NET API solution.
see
http://usa.autodesk.com/adsk/servlet/index?id=18162650&siteID=123112
http://through-the-interface.typepad.com/through_the_interface/2012/03/migrating-net-applications-to...
for more information
(defun botsbuildbots() (botsbuildbots))
hgasty1001
You need to change the references and recompile for each version 2012/2013, as AutoCAD 2013 has changes in the API (some things were moved from one dll to another, and other changes)  also, 2013, added a new dll to reference in the project (AcCoreMgd.dll).
Gaston Nunez
