First Question
First Question
Amremad
First Question
Amremad
can i make a function by .net then link this function with command lisp
run when the user write the command lisp ???? "like vba with vl-vbarun "
if yes - how can i start?
arcticad
http://through-the-interface.typepad.com/through_the_interface/2006/07/breathe_fresh_l.html
(defun botsbuildbots() (botsbuildbots))
chiefbraincloud
Yes.  You define the command with the LispFunction attribute, then from lisp, you call it like any other lisp function.
As far as where to start, I suggest downloading the ObectARX SDK for the version of AutoCAD you will be working with, and looking at the .NET Developers Guide.
This is a decent start: http://through-the-interface.typepad.com/through_the_interface/2006/07/breathe_fresh_l.html
Edit: I see while I was digging around for the hyperlinks arcticad already gave you that one.
Amremad
But I don’t know where can I write the vb.net or c#.net code ,
I downloaded and installed objectARX object source but I don’t know how to start, and where 's it's interface editing code?
Can someone explain this subject simply plz
Sorry for my english
Alexander.Rivilis
DevTV and AutoCAD .NET Labs can help you: http://adndevblog.typepad.com/autocad/2012/05/devtv-autocad-net-labs.html
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
dgorsman
In that case, I would suggest getting a handle on VB or C# development first before attempting to program for AutoCAD - you will lose less hair that way.  Check out Visual Studio Express from Microsoft as your IDE.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
