.NET
Valued Contributor
yaqiz
Message 1 of 11 (329 Views)
Finding out when a custom PaletteSet is closed in AutoCAD using .NET code crash
329 Views, 10 Replies
07-03-2012 01:06 AM
Hi Guys,
I would like to do something when my paletteset is closed. I took the C# code from here
http://through-the-interface.typepad.com/through_the_interface/2011/12/finding-out-when-a-custom-pal...
I modified the code to VB.net
    Dim WithEvents ps As Autodesk.AutoCAD.Windows.PaletteSet
    <Autodesk.AutoCAD.Runtime.CommandMethod("psTest")> _
    Public Sub PSTest()
        If ps Is Nothing Then
            ps = New Autodesk.AutoCAD.Windows.PaletteSet("psTest")
            ps.Dock = Autodesk.AutoCAD.Windows.DockSides.Left
            ps.Visible = True
        End If
    End Sub
    Private Sub ps_StateChanged(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.Windows.PaletteSetStateEventArgs) Handles ps.StateChanged
        If e.NewState = Autodesk.AutoCAD.Windows.StateEventIndex.Hide Then
            Application.DocumentManager.MdiActiveDocument.SendStringToExecute("CHECKPALETTESETCLOSE", True, True, False)
        End If
    End Sub
    <Autodesk.AutoCAD.Runtime.CommandMethod("CHECKPALETTESETCLOSE", CommandFlags.NoHistory)> _
    Public Sub CheckPaletteSetState()
        If Not ps Is Nothing And ps.Visible = False Then
            Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("closed")
        End If
    End Sub
My code crashed. If I catch exception it is eInvalidInput exception. I don't know what to do as it is a simple code segment I don't know hot to fix it.
Any ideas?
Alfred.NESWADBA
Message 2 of 11 (328 Views)
Re: Finding out when a custom PaletteSet is closed in AutoCAD using .NET code cr
07-03-2012 01:11 AM in reply to: yaqiz
first guess: don't check only for "Is Nothing" but also for "ps.IsDisposed"
HTH, - alfred -
Alfred NESWADBA
Valued Contributor
yaqiz
Message 3 of 11 (327 Views)
07-03-2012 01:14 AM in reply to: Alfred.NESWADBA
Thanks for reply
the problem comes from here
            Application.DocumentManager.MdiActiveDocument.Send​StringToExecute("CHECKPALETTESETCLOSE", True, True, False) '--here is the exception
        End If
    End Sub
Alfred.NESWADBA
Message 4 of 11 (324 Views)
07-03-2012 01:26 AM in reply to: yaqiz
are you sure that you can run SendStringToExecute during this eventhandling? I fear NO ... to verify that: what happens if you send a _LINE-command?
PLUS: as it's a command defined by your app, why do you run this code with SendStringToExecute?
- alfred -
Alfred NESWADBA
Valued Contributor
yaqiz
Message 5 of 11 (323 Views)
07-03-2012 01:31 AM in reply to: Alfred.NESWADBA
Thanks for reply. I don't know I took code from the post I found online(you can see in my main post). What I have done modify from c# to vb.net
I got reply from AutoCAD API support. They can replicate my issue. What I really want to do is to catch when user click paletteset "x" button rather than "-".
Alfred.NESWADBA
Message 6 of 11 (311 Views)
07-03-2012 08:51 AM in reply to: yaqiz
in most cases when using events where I need to run SendCommand (or similar) I usually redirect the event to a position when AutoCAD get's quiescent.
So in your eventhandler create a new one using AddHandler that points to a sub handling then the reached quiesent-state for AutoCAD.
HTH, - alfred -
Alfred NESWADBA
chiefbraincloud
Message 7 of 11 (304 Views)
07-03-2012 11:58 AM in reply to: Alfred.NESWADBA
From the next TTIF post after the one in the link above.
Something I should have mentioned about the reason for implementing a command, in the first place: the standard StateChanged event gets fired twice when undocking a palette set – once to hide it and once to display it again. This means we can’t assume a hide notification means the palette set is being closed – we really need to wait until the dust has settled before checking the state of the palette set in order to proclaim our verdict. Which is why we’re sending a command to be executed
Valued Contributor
yaqiz
Message 8 of 11 (287 Views)
07-04-2012 01:55 AM in reply to: chiefbraincloud
Thanks for your reply.
Have you try to implement that code segement? Does that work as it should be?
chiefbraincloud
Message 9 of 11 (272 Views)
07-05-2012 12:31 AM in reply to: yaqiz
Sorry, I don't really like palettes, and they don't really fit in with the kind of automations I am writing.  So, no, I have not tried the code to verify it's operation.  I just replied to try and answer Alfred's question about why the code uses a SendStringToExecute.
Valued Mentor
DiningPhilosopher
Message 10 of 11 (266 Views)
07-05-2012 01:05 PM in reply to: yaqiz
You are not logged in.
Ask the Community
