Can someone please let me know the command to read/write entity property via dxf index number like this.
Is this what you are looking for (please review attached pdf): DXF references list (full).
hope this helps.
regards,
Ben
Thats dependant on how the information is stored. For example, XRecords use one set of DXF codes (which match standard AutoCAD DXF codes) while XDATA uses its own set of DXF codes. The actual meaning of the data in both cases is left up to the user to decide its context ie. a coordinate value could be a start point, or end point, or even a vector.
Hi Dgors
I tried dbobject.xdata(retrieved all registered application), and I can get some dxf code value associated with 1000~1005 or so. My issue is like someone said reverse engineering on customized object (IMPEntity). That object stored data associated with dxfcode 1. Now I'm using resultbuffer / ivoke to have a LISP program run and get the value. If vb.net has the same ability like (print (nth ct entl)), as posted by Adam above (I tried Adam's LISP program, it's just brilliant well), I shouldn't have trouble struggling with LISP. Thank you!
Hi
You able to find some solution or using lisp command. I am searching for the solution as well and so far I have the lisp solution as well and not something in .NET
Regards
Salman
maybe use MgdDbg, should have a DXF filer
https://github.com/ADN-DevTech/MgdDbg
Thanks Daniel for sharing the ArxDbg .NET version and I am able to give it a try. I was not aware of this tool so good to know and I have this code that will be handy in future.
However it doesn't have the DXF option as available in the regular ARXDBG comes with SDK.
