.NET
Distinguished Contributor
JanetDavidson
Message 1 of 7 (229 Views)
Find Clip Id from NonRectangularViewPort Object ID t?
229 Views, 6 Replies
12-04-2012 09:14 PM
Need help  and could not find a solution for it.
I have  the ID of non rectangular view port and I need to find the Polyline attached to it.
How do you do that ?
Moderator
Alexander.Rivilis
Message 2 of 7 (223 Views)
Re: Find Clip Id from NonRectangularViewPort Object ID t?
12-04-2012 09:52 PM in reply to: JanetDavidson
Hi, Janet!
Please attach a simplest dwg-file with such viewport and correspondent Polyline.
P.S.: Maybe method Viewport.NonRectClipEntityId can help you?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
khoa.ho
Message 3 of 7 (221 Views)
12-04-2012 09:58 PM in reply to: JanetDavidson
Once you have a viewport ObjectId, use viewport.NonRectClipEntityId (that should be not ObjectId.Null) to get its non-rectangular viewport, see the following code snippet:
transaction.GetObject(viewport.NonRectClipEntityId, OpenMode.ForRead) as Polyline
-Khoa
JanetDavidson
Message 4 of 7 (203 Views)
12-05-2012 05:11 AM in reply to: JanetDavidson
Thanks Khao for your time,
 Actually My Problem it the otherway around.  I mean I want the PolyLine ObjectId of sorrouding ViewPort (Which I have the ID.
JanetDavidson
Message 5 of 7 (202 Views)
12-05-2012 05:11 AM in reply to: Alexander.Rivilis
Hi Alex,
I need the object ID of Polyline which is attached to viewport.
Moderator
Alexander.Rivilis
Message 6 of 7 (193 Views)
12-05-2012 05:52 AM in reply to: JanetDavidson
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(Rivilis.Lesson))]
namespace Rivilis
  public class Lesson
    [CommandMethod("TestViewport")]
    public void TestViewport()
      Document doc = Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      PromptSelectionResult res = ed.GetSelection();
      if (res.Status == PromptStatus.OK) {
        using (Transaction t = doc.TransactionManager.StartTransaction()) {
          foreach (ObjectId id in res.Value.GetObjectIds()) {
            Viewport vp = t.GetObject(id, OpenMode.ForRead) as Viewport;
            if (vp != null) {
              ObjectId idPoly = vp.NonRectClipEntityId;
              if (!idPoly.IsNull) {
                // ObjectId of polyline
                ed.WriteMessage("\nid = {0} NonRectClipEntityId = {1}", id, idPoly);
              else {
                ed.WriteMessage("\nid = {0} Viewport is not clipping with polyline", id);
            else {
              ed.WriteMessage("\nid = {0} is not Viewport", id);
          t.Commit();
http://www.developerfusion.com/tools/convert/csharp-to-vb/  for converting C# to VB.NET
JanetDavidson
Message 7 of 7 (161 Views)
12-05-2012 07:15 PM in reply to: Alexander.Rivilis
Alex Thank you so much. That was it.
You are not logged in.
Ask the Community
