.NET
Rob.O
Message 1 of 4 (374 Views)
Accepted Solution
Filter multiple object types
374 Views, 3 Replies
04-11-2012 12:18 PM
Hi all!
I have searched for info on how to filter multiple object types (here, the swamp, google, and the docs) and have come up empty handed.  I have code that filters out everything except for blocks (INSERT) with a few additional parameters to exclude blocks of a certain name, but I also need to include MULTILEADERS in the selection filter.
Here is the code I have for the INSERT filter:
acTypValAr = New TypedValue() {New TypedValue(DxfCode.Start, "INSERT"), New TypedValue(-4, "<NOT"), _
                                      New TypedValue(2, "BLOCKA,BLOCKB,BLOCKC,BLOCKD"), _
                                      New TypedValue(-4, "NOT>")}
 Any ideas on how to add MULTILEADERS to this selection filter as well?
Valued Contributor
FFlix
Message 2 of 4 (363 Views)
Re: Filter multiple object types
04-11-2012 01:28 PM in reply to: Rob.O
hi, have you tried adding 'New TypedValue(DxfCode.Start, "MLEADER")' into the parameter list?
(autodesk's dxf reference lists MLEADER in the same way as INSERT for blockreferences, along with further distinction into mleader context, mleader node and mleader line.)
*Expert Elite*
_gile
Message 3 of 4 (357 Views)
Re : Filter multiple object types
04-11-2012 01:42 PM in reply to: Rob.O
While the values are strings in a selection filter TypedValue, you can have multiple strings separated with commas (as with your block names):
new TypedValue(0, "INSERT,MULTILEADER");
The more complete documentation about selection filters is in the LISP docs:
Developer Documentation > AutoLISP Developer's Guide > Using the AutoLISP Language > Using AutoLISP to Manipulate AutoCAD Objects > Selection Set Handling > Selection Set Filter Lists and related topics. Just repalce LISP dotted pairs with TypedValues.
Gilles Chanteau
Rob.O
Message 4 of 4 (342 Views)
04-11-2012 03:05 PM in reply to: _gile
Perfect!
I didn't even think of trying that Gile!
Thanks!
You are not logged in.
Announcements
Need installation help?
Ask the Community
