.NET
Luigi71
Message 1 of 4 (212 Views)
File name
212 Views, 3 Replies
11-19-2012 01:46 AM
Hi to all.
I'm trying to save two drawings sequentially with the following code:
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Public Class Class1
<CommandMethod("SaveTwoDrawings")> _
Public Sub SaveTwoDrawings()
Dim doc As Document
Dim strDWGName As String
Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
Dim obj As Object
doc = acDocMgr(0)
strDWGName = doc.Name
strDWGName = "c:\MyDrawing#1.dwg"
doc.Database.SaveAs(strDWGName, True, DwgVersion.Current, doc.Database.SecurityParameters)
doc = acDocMgr(1)
strDWGName = "c:\MyDrawing#2.dwg"
End Sub
End Class
While the two drawings are correctly saved in the desired position whith the desired names, only the name of the last drawing is updated ("Drawing2.dwg"--->"MyDrawing#2.dwg"), but the name of the first drawing still remains the original assigned by autocad "Drawing1.dwg", the autocad title bar is not updated too.
Some suggestions?
Alfred.NESWADBA
Message 2 of 4 (206 Views)
Re: File name
11-19-2012 02:07 AM in reply to: Luigi71
try to use the "Session"-flag for your command-definition:
   <CommandMethod("SaveTwoDrawings", Autodesk.AutoCAD.Runtime.CommandFlags.Session)> _
   Public Shared Sub SaveTwoDrawings()
- alfred -
Alfred NESWADBA
Luigi71
Message 3 of 4 (192 Views)
Re: File name
11-19-2012 04:40 AM in reply to: Luigi71
Thanks Alfred.
Tried the suggestion, but still not working.
Luigi71
Message 4 of 4 (159 Views)
Re: File name
11-20-2012 12:21 AM in reply to: Alfred.NESWADBA
Hi Alfred, I modified the code like this (including your suggestion).
Public Class Class1
<CommandMethod("SaveTwoDrawings", CommandFlags.Session)> _
Dim doc As Document
Dim obj As Object
doc = acDocMgr(0)
acDocMgr.MdiActiveDocument = doc
doc = acDocMgr(1)
End Sub
End Class
In this case the routine works fine.
It seems that there is a need to make the document active. When the document is active the doc.Name property is updated.
Using Autocad 2010 32bit, Visual Studio Espress 2008
You are not logged in.
Ask the Community
