.NET
Fields and excessive Xrecords in dynamic blocks
2 REPLIES 2
396 Views, 2 Replies
Hi all
I've recently made the jump into .net development and I'm fairly happy with progress so far.
I've managed to make a custom jig that does pretty much everything I want it to do, but with a couple of issues:
  1. After entering the first click the block then starts generating xrecords and dbdictionaries (I'm using the Autodesk tutorial code that adds a palette that displays all drawing objects as they're added). I have no code that explicitly does this as I don't need xrecords at this stage. The code that appears to be generating them is below:
Case
1
'if second click
IfNot _scanned1 Then
ForEach objItem AsDynamicBlockReferencePropertyIn block.DynamicBlockReferencePropertyCollection
If objItem.PropertyName.ToString() = "length"AndNot _found1 Then
                                    _length = objItem
                                    _found1 =True
ElseIf objItem.PropertyName.ToString() = "height"AndNot _found2 Then
                                    _height = objItem
                                    _found2 =True
ElseIf _found1 And _found2 Then
                                    _scanned1 =True
                                   Exit For
EndIf
Next
                            ed.WriteMessage("Parameters identified")
EndIf
                        _length.Value = _pos2.X - _pos.X
                        _height.Value = _pos2.Y - _pos.Y
If _length.Value < 0 Then
                            _length.Value = _length.Value * -1
EndIf
If _height.Value < 0 Then
                            _height.Value = _height.Value * -1
EndIf
The problem with the creation of the xrecords and dbdictionaries is that it slows everything down. They seem to be created everytime you move the mouse...
2.     I'm struggling with fields. There is a field in an attribute of the block that reads the area from the only polyline that's in the block. I think the difficulty I'm having is iterating through the block to find the polyline and its objectid. Without the objectid I can't apply the field. Code is below:
If
blockTableRecord.HasAttributeDefinitions Then
ForEach id AsObjectIdIn blockTableRecord
Dim obj AsDBObject = trans.GetObject(id, OpenMode.ForRead)
Dim attDef AsAttributeDefinition = TryCast(obj, AttributeDefinition)
IfTypeOf obj IsPolylineThen
                            ed.WriteMessage("Polyline found")
                            objId = obj.ObjectId
EndIf
If attDef IsNotNothingAndAlsoNot attDef.Constant Then
Dim attRef AsAttributeReference = NewAttributeReference
                            attRef.SetAttributeFromBlock(attDef, block.BlockTransform)
                            attRef.Position = attDef.Position.TransformBy(block.BlockTransform)
If attDef.Justify <> AttachmentPoint.BaseLeft Then
                                attRef.AlignmentPoint = attDef.AlignmentPoint.TransformBy(block.BlockTransform)
EndIf
If attRef.IsMTextAttribute Then
                                attRef.UpdateMTextAttribute()
EndIf
If attRef.Tag = "STANDAREA"Then
'ed.WriteMessage(vbLf & "Attribute has a field")
                                attRef.TextString ="%<\AcObjProp Object(%<\_ObjId " + objId.ToString() + ">%).Area>%"
EndIf
'---------------------------etc
Apologies if these questions have been answered before, but I can't find anything that's specific to these issues.
MrRamsden
2 REPLIES 2
For anyone who cares, I changed my jig to draw a rectangle which is used to size and position the block, so the heavy blockJig stuff doesn't happen.
I managed to cycle through the blockTableRecord of the block and find the polyline and the field now works perfectly. I think I managed to find an example of how to do it properly on here eventually, but if anyone wants it just ask.
cincir
try this instead
If blockTableRecord.HasAttributeDefinitions Then
EndIf
EndIf
EndIf
EndIf
”Boost
