.NET
Active Member
latoge
Message 1 of 3 (140 Views)
Fatal error override WorldDraw
140 Views, 2 Replies
01-30-2013 06:51 AM
have a function that allows the user to set a color on a modified dimension (only the text of it).  However, when this function is enabled and the user wants stretch the dimension, Autocad make a fatal error and close.
Here is where it crash (in red) :
public overridebool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.Drawable drawable, Autodesk.AutoCAD.GraphicsInterface.WorldDraw wd)
            if (showText || resetText)
                   Dimension dm = (Dimension)drawable;
                    dm.UpgradeOpen();
                    dm.Dimclrt = dimTColor;
                    dm.DowngradeOpen();
I added this (in red) but it will just turn in round in my code with another function and made the fatal error still :
                    if(!dm.IsWriteEnabled)
                          dm.UpgradeOpen();
                          dm.DowngradeOpen();
Let me know if you need to see more of my code.  Thank you
ADN Support Specialist
Balaji_Ram
Message 2 of 3 (110 Views)
Re: Fatal error override WorldDraw
02-06-2013 04:01 AM in reply to: latoge
How about trying to create a clone of the dimension and then change its color and use it to draw ?
This way, it will not be needed to work with the original dimension.
If that does not help, can you please share a buildable sample project to demonstrate the problem ?
Balaji
Developer Technical Services
Autodesk Developer Network
Active Member
latoge
Message 3 of 3 (91 Views)
02-13-2013 06:56 AM in reply to: latoge
Thank you for your answer.  It's a good idea, I will work on that !
You are not logged in.
Ask the Community
