.NET
Active Contributor
bkenyon13
Message 1 of 14 (388 Views)
Fatal Exception when running code
388 Views, 13 Replies
05-25-2012 06:56 AM
I have been trying to figure this out for a while and I just can't pin point why I get a fatal exception when running this code (see code below).
I have done this same code (for the mose part) to import pagesetups into the active document and it works fine.  however when I run it as it is here to import the page setups into other drawings it seems to always crash autocad.
please help!!!!
Code:
Private Sub copy_click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles copy.Click
        Dim psdb As New Database(False, True)
        psdb.ReadDwgFile("M:\CAD Management\CAD Files\Template\Basic.dwt", FileOpenMode.OpenForReadAndReadShare, True, "")
        For Each item In ListBox1.Items
            Dim db As New Database(True, False)
            db.ReadDwgFile(item.ToString, FileOpenMode.OpenForReadAndAllShare, False, "")
            Using trans As Transaction = psdb.TransactionManager.StartTransaction
                Using trns As Transaction = db.TransactionManager.StartTransaction
                    Dim psd As DBDictionary = trans.GetObject(psdb.PlotSettingsDictionaryId, OpenMode.ForRead)
                    Dim id As ObjectId
                    Dim pd As DBDictionary = trns.GetObject(db.PlotSettingsDictionaryId, OpenMode.ForRead)
                    For Each entry As DBDictionaryEntry In pd
                        pd.UpgradeOpen()
                        pd.Remove(entry.Value)
                        pd.DowngradeOpen()
                    Next
                    For Each psent As DBDictionaryEntry In psd
                        id = psd.GetAt(psent.Key)
                        Dim ps As PlotSettings = id.GetObject(OpenMode.ForRead)
                        Dim curps As PlotSettings = New PlotSettings(False)
                        curps.CopyFrom(ps)
                        curps.AddToPlotSettingsDictionary(db)
                        curps.DowngradeOpen()
                    Next
                    trns.Commit()
                    db.SaveAs(item.ToString, DwgVersion.Current)
                    db.CloseInput(True)
                    db.Dispose()
                    trns.Dispose()
                End Using
                trans.Dispose()
            End Using
        Next
        psdb.CloseInput(True)
        psdb.Dispose()
        Me.Close()
    End Sub
Member
CarterN
Message 2 of 14 (384 Views)
Re: Fatal Exception when running code
05-25-2012 06:58 AM in reply to: bkenyon13
What type of exception are you getting? What line are you getting the exception on?
Active Contributor
bkenyon13
Message 3 of 14 (381 Views)
05-25-2012 07:18 AM in reply to: CarterN
here is the error that I get:
FATAL ERROR: Unhandled Access Violation reading 0xffffffff Exception at db9acc52h
This will either happen after running the code and I start to do something else in autocad or when I close autocad.
I know it has something to so with the code that I am running as it only happens when I run the code.
also it only seems to happen with the portion of copying the pagesetups, I am not sure what the exact cause is, or which line causes it as it happens after running the code and no other errors appear except the one above.
is there a way to have it go line by line and run the code and then even after it runs have it give me any errors witht he code?
Member
CarterN
Message 4 of 14 (379 Views)
05-25-2012 07:26 AM in reply to: bkenyon13
This one is beyond me, I only asked cause your code looks similar to my own and I am encountering a similar issue.
Looks like we are both stuck then!
Active Contributor
bkenyon13
Message 5 of 14 (375 Views)
05-25-2012 07:33 AM in reply to: CarterN
My theory is that there is something that is hanging out there that I need to stop or close or something that is causeing the error, but I am not sure if that is the case or even how I can tell what it is.
If I figure out an answer and get this working I will be sure to post it.
dgorsman
Message 6 of 14 (371 Views)
05-25-2012 07:34 AM in reply to: bkenyon13
Doesn't Using... negate the need to Dispose() those transactions?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Hallex
Message 7 of 14 (371 Views)
05-25-2012 07:38 AM in reply to: bkenyon13
Use LockDocument if you're working with external drawings,
search for "Unhandled Access Violation" on this NG
~'J'~
Active Contributor
bkenyon13
Message 8 of 14 (367 Views)
05-25-2012 08:04 AM in reply to: Hallex
would I lock each external document?
or where would I use the LockDocument?
Hallex
Message 9 of 14 (365 Views)
05-25-2012 08:25 AM in reply to: bkenyon13
Use DocumentLock just for current drawing:
databse db=hostapplicationservices.workingdatabase
document doc=application.documentmanager.mdiactivedocument
using doclock as  DocumentLock= doc.LockDocument' current document where you working
using newdb as Database=Readdwg()
using tx as transaction=db.transactionmanager.starttransaction
'' do you work here
end using 'tx
end using 'newdb
end using'' doclock
Active Contributor
bkenyon13
Message 10 of 14 (362 Views)
05-25-2012 08:46 AM in reply to: Hallex
ok, I have changed my code on this and I have finally gotten it to work without crashing autocad.
not sure if it is the dispose parts that I have added
or if it was the exit for parts that I have added, put either way it works without crashing.
hope this helps others
code:
        Using lock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument
            Try
                psdb.ReadDwgFile("M:\CAD Management\CAD Files\Template\Basic.dwt", FileOpenMode.OpenForReadAndReadShare, False, "")
                            Dim id As ObjectId
                                pd.UpgradeOpen()
                                pd.DowngradeOpen()
                                Exit For
                            Next
                                curps.CopyFrom(ps)
                                trns.Commit()
                                curps.Dispose()
                                Exit For
                            Next
                            psd.Dispose()
                            pd.Dispose()
                        End Using
                        db.CloseInput(True)
                        db.Dispose()
                        Exit For
                    Next
                End Using
                psdb.Dispose()
            Catch ex As System.Exception
                MsgBox(vbLf & ex.Message)
            End Try
        End Using
        Me.Close()
    End Sub
You are not logged in.
Ask the Community
