.NET
Active Contributor
greg
Message 1 of 14 (379 Views)
Failed to get selectionresult
379 Views, 13 Replies
08-28-2013 07:07 PM
I have an application that utilizes this code to select entities
For x = 0 To SelectionSetEntitiesBindingSource.Count - 1
     ObjectIDs(x) = ObjectIdFromHandle(myDocDB, SelectionSetEntitiesBindingSource(x)("ACADHandle").ToString)
Next
Autodesk.AutoCAD.Internal.Utils.SelectObjects(ObjectIDs)
And then this code to build a selection set from those entities
    Public Function GetSelectionSet() As SelectionSet
        Dim myDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim myDocDB As Database = myDoc.Database
        Dim ed As Editor = myDoc.Editor
        Dim prObjectSelectionRes As PromptSelectionResult
        prObjectSelectionRes = ed.SelectImplied()
        If prObjectSelectionRes.Status = PromptStatus.OK Then
            GetSelectionSet = prObjectSelectionRes.Value
        Else
            MsgBox("An error occurred getting the selection set.", vbOKOnly, "Error")
            Exit Function
        End If
    End Function
This works fine for a while, but eventually the second part of the code failes at prOjectSelectionRes = ed.selectImplied...or rather not fails but returns error -5001.
This appears to be directly related to the number of times I call this function as though there is a limit to the number of sets you can create in an instance of Autocad...or something similar.
These entities are being retrieved from a database which is the reason for the loop in the first part.  I execute the code and it will run for a while going through the different tables in the db.
Any help is greatly appreciated.
Thanks!
Active Contributor
greg
Message 2 of 14 (350 Views)
Re: Failed to get selectionresult
08-29-2013 05:03 AM in reply to: greg
Just to add a bit more.
It appears when I get out of the command and I select something on screen I can not hit the esc key to cancel the selection...really weird behavior within model space until I change to a layout and back to model space does it fix itself.
arcticad
Message 3 of 14 (340 Views)
08-29-2013 06:22 AM in reply to: greg
This is the method I've used, it also lets me hit the space bar to repeat the command.
Private Sub btnSelectBlock_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnSelectBlock.Click
    If Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Count = 0 Then
        Exit Sub
    End If
    curDoc.SendStringToExecute(Chr(27), False, False, False)
    curDoc.SendStringToExecute("MyCommand" & vbCr, False, False, False)
    Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView()
End Sub
<CommandMethod("MyCommand")> _
Public Sub selectBlock()
End Sub
(defun botsbuildbots() (botsbuildbots))
Active Contributor
greg
Message 4 of 14 (332 Views)
08-29-2013 06:55 AM in reply to: arcticad
Thanks for the response but not sure how that would help me.
Workflow of the application:
  • Application is executed
  • Form opens with various settings.
  • Button is clicked
  • Application makes connection to external database table as a binding source
  • Application loops through binding source where Handle is stored of the drawing objects.
  • Application selects drawing entites based the handles from the bindingsource.
  • Application performs action on entities
  • Application makes another connect to external database for another table table and sets as binding source
  • This process continues through many different tables..right now about 5 or so but will most likely be added to as time goes on.
I dont need to rexecute the command with the space bar..not a concern really.
Any other ideas?
arcticad
Message 5 of 14 (321 Views)
08-29-2013 07:33 AM in reply to: greg
    <CommandMethod("MyCommand", CommandFlags.Modal Or CommandFlags.UsePickSet Or CommandFlags.Redraw)> _
    Public Sub MyCommand()
        GetSelectionSet()
    End Sub
This worked for getting the implied selection set.
There is a limit of 128 selection set open at one time.
Active Contributor
greg
Message 6 of 14 (311 Views)
08-29-2013 07:46 AM in reply to: arcticad
if you meant I should include "CommandFlags.Modal Or CommandFlags.UsePickSet Or CommandFlags.Redraw" on the original entry...I just did that and it did not fix the issue.
arcticad
Message 7 of 14 (304 Views)
08-29-2013 08:03 AM in reply to: greg
http://spiderinnet1.typepad.com/blog/2012/09/autocad-net-count-limit-of-available-selection-sets.htm...
Active Contributor
greg
Message 8 of 14 (287 Views)
08-29-2013 03:20 PM in reply to: arcticad
Thank you!  It appears this may be the problem.  However I am still in the process of altering my code to explicitly dispose of all selectionsets that are created.
I will let you know.
Thanks again.
Active Contributor
greg
Message 9 of 14 (278 Views)
08-29-2013 06:25 PM in reply to: greg
So I took the code in the link you provided and modified it a bit to use the general functionality that I am using and this replicates the error I am receiving exactly.  Bombs out at 128 which I suppose makes sense.  The problem is that I am not sure why. I am disposing my selection set with each run through the loop.  Is there something else?
    <CommandMethod("TestSelectionSetCountLimit2", CommandFlags.Modal Or CommandFlags.UsePickSet Or CommandFlags.Redraw)> _
    Public Sub TestSElectionSetCountLimit2()
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Try
            For i = 0 To 130
                Dim ObjectIDs(0) As ObjectId
                ObjectIDs(0) = ObjectIdFromHandle(db, "A33DC")
                    Dim ss As SelectionSet
                    ss = prObjectSelectionRes.Value
                    If ss IsNot Nothing Then
                        ed.WriteMessage(vbLf & "The #{0} SS is good and has {1} entities.", i + 1, ss.Count)
                        ss.Dispose()
                    Else
                        ed.WriteMessage(vbLf & "The #{0} SS is bad!", i + 1)
                    End If
                Else
                End If
            Next
        Catch ex As System.Exception
            ed.WriteMessage(ex.ToString())
        End Try
    End Sub
Active Contributor
greg
Message 10 of 14 (249 Views)
08-30-2013 04:07 AM in reply to: greg
I should also add that you can easily duplicate the error by just replacing the handle with one from your drawing and using the below "ObjectIDfromHandle" function I forgot to include.
    Public Shared Function ObjectIdFromHandle(db As Database, strHandle As String) As ObjectId
        Dim nHandle As Int32 = Int32.Parse(strHandle, Globalization.NumberStyles.AllowHexSpecifier)
        Dim handle As New Handle(nHandle)
        Dim ids(0) As ObjectId
        ids(0) = db.GetObjectId(False, handle, 0)
        Return ids(0)
        'Return db.GetObjectId(False, handle, 0)
    End Function
You are not logged in.
Ask the Community
