Hello everybody !
My first post here 😉
Many thanks to everybody reading it 😉
Context :
Business Requirement :
The application manages some objects (features), containing business attributes and a geometry attribute (in an FDO meaning).
One of these business attributes should contain the length of the item drawn under AutoCAD Map.
If a user wants to modify the geometry of one of these items (by moving vertices for example), he must check out the feature of its choice (a polyline, or a point).
Then he can update the geometry of the feature, and finally, he has to check in the feature to store it permanently.
When checking-in the feature, I need to get the new length of the polyline (or new coordinates of a point for example), and I need to update the appropriate business attribute of the relevant object with the new length.
My technical implementation, not working :
I've handled the CommandEventHandler "CommandEnded" of the Document Object (Autodesk.AutoCAD.ApplicationServices.Document). This event is raised when an AutoCAD Map Command has ended. In this handler, I test the GlobalCommandName of the Event Argument. I test "MAPCANCELCHECKOUT", "MAPCHECKOUT" and "MAPCHECKINALL".
void doc_CommandEnded(object sender, CommandEventArgs e) { Document doc = (Document)sender; Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor; switch (e.GlobalCommandName) { case "MAPCANCELCHECKOUT": CancelCheckOut(); break; case "MAPCHECKOUT": DoCheckOut(); break; case "MAPCHECKINALL": DoCheckIn(); break; default: break; } ed.WriteMessage("\nCommand ended : [" + e.GlobalCommandName + "]"); } Dictionary<ObjectId, TakmGenericObject> __objectsIdToTakmGenericObjectsCheckedOut = new Dictionary<ObjectId, TakmGenericObject>(); public void DoCheckOut() { Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; Editor ed = doc.Editor; PromptSelectionResult result = ed.GetSelection(); SelectionSet selSet = result.Value; AcMapMap currentMap = AcMapMap.GetCurrentMap(); MgLayerCollection layers = currentMap.GetLayers(); Database db = doc.Database; using (Transaction acTrans = db.TransactionManager.StartTransaction()) { foreach (SelectedObject selObj in selSet) { // Check to make sure a valid SelectedObject object was returned if (selObj != null) { // Open the selected object for write SelectionSet selSet2 = SelectionSet.FromObjectIds(new ObjectId[1] { selObj.ObjectId }); AcMapSelection sel = (AcMapSelection)AcMapFeatureEntityService.GetSelection(selSet2); foreach (MgLayerBase layer in layers) { Int32 iCount = sel.GetSelectedFeaturesCount(layer, layer.FeatureClassName); if (iCount>0) { // Getting Relevant Business Object MgFeatureReader reader = sel.GetSelectedFeatures(layer, layer.FeatureClassName, false); Collection<Object> ids = new Collection<Object>(); while (reader.ReadNext()) { Int64 id = reader.GetInt64("ID"); ids.Add(id); ed.WriteMessage("\nID: " + id); } String shortName = (layer.FeatureClassName.Contains(':') ? layer.FeatureClassName.Substring(layer.FeatureClassName.IndexOf(':') + 1) : layer.Name); TakmGenericObjectCollection<TakmGenericObject> goCollection = new TakmGenericObjectCollection<TakmGenericObject>(); goCollection.Descriptor = TakmGenericObjectDescriptorDictionary.Instance.GetFirstGenericObjectDescriptorByTableName(shortName); if (goCollection.Descriptor != null) { goCollection.SelectWherein("ID", ids); foreach (TakmGenericObject genericObject in goCollection) { // Putting Key-Value into Dictionary __objectsIdToTakmGenericObjectsCheckedOut.Add(selObj.ObjectId, genericObject); } } } } } } } } public void DoCheckIn() { Collection<ObjectId> unlocked = new Collection<ObjectId>(); Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; using (Transaction acTrans = db.TransactionManager.StartTransaction()) { foreach (KeyValuePair<ObjectId, TakmGenericObject> kvp in __objectsIdToTakmGenericObjectsCheckedOut) { FeatureToDraw feature = new FeatureToDraw(); try { // // // DBObject dbObj = acTrans.GetObject(kvp.Key, OpenMode.ForRead, true); // ---> this line always generate exception! // // Polyline pl = dbObj as Polyline; if (pl != null) { feature.Length = pl.Length; } Curve crv = dbObj as Curve; if (crv != null) { feature.Length = crv.GetDistanceAtParameter(crv.EndParam) - crv.GetDistanceAtParameter(crv.StartParam); } TakmGenericObject genericObject = kvp.Value; if (genericObject.Descriptor != null) { // Updating Business attributes of Business Objects // new length, new coordinates // blablabla... } } catch (System.Exception ex) { TakmLogger.Instance.LogError(__classFullName + "DoCheckIn", ex.Message); if (ex.InnerException != null) { TakmLogger.Instance.LogError(__classFullName + "DoCheckIn", ex.InnerException.Message); } } } } foreach (ObjectId objId in unlocked) { __objectsIdToTakmGenericObjectsCheckedOut.Remove(objId); } }
Can someone help me please ?
Do I had made the good choice ?
Is there any best practice regarding my needs ?
Thank you very much.
tom.
Solved by alberto_manero_geograma. Go to Solution.
I think that for the MAPCHECKINALL probably you shoud do the process before the command begins. Could it be?
Hi amareno,
it works like a charm !
Thank you so much. I just handle the CommandWillStart Event, just before the MAPCHECKINALL command is really executed.
Document.CommandWillStart += new CommandEventHandler(doc_CommandWillStart);
And at this time, when I call the GetObject, I get the result !
Many Thanks again.
tom.
