.NET
Active Contributor
dnlo
Message 1 of 3 (221 Views)
Extracting Line properties from selection set, C# via COM
221 Views, 2 Replies
04-05-2006 02:09 AM
I'm using ActiveX methods from C#. I have a selection set of AcadLine entities and need to access their StrartPoint, EndPoint values. I get an object in selection set and trying to cast to AcadLine, then access its values. The code compiles, but at runtime have an error, saying the object referenced has not been instantiated. What is the problem?
How to get AcadLine properties from selection set?
Thanks in advance.
*Tony Tanzillo
Message 2 of 3 (221 Views)
Re: Extracting Line properties from selection set, C# via COM
04-05-2006 03:33 AM in reply to: dnlo
Are you expecting someone to guess what your code
isn't doing correctly?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5132413@discussion.autodesk.com...
Thanks in advance.
Active Contributor
dnlo
Message 3 of 3 (221 Views)
04-05-2006 05:27 AM in reply to: dnlo
Sorry,
the code is something like that:
for (...)
AcadEntity objInSset = sSetAllObjects((object) i);// sSetAllObject - selection set
AcadLine lineInSset;
lineInSset =(AcadLine)objInSset();
SomeDynamicArray.Add(lineInSset.Endpoint);//here is the problem
You are not logged in.
Announcements
Need installation help?
Ask the Community
