.NET
mzakiralam
Message 1 of 3 (167 Views)
Extract co-ordinates from TEXT file and draw object in those (x,y,z) points
167 Views, 2 Replies
12-09-2012 11:21 AM
HI All,
I want extract a (x,y,z) point from a text file and want to put marker to that point in a dwg file. how can I accomplish that? Can anybody give me a hint or same code in VB.
Thanks in advance.
Regards
Zakir
*Expert Elite*
Hallex
Message 2 of 3 (143 Views)
Re: Extract co-ordinates from TEXT file and draw object in those (x,y,z) points
12-09-2012 11:28 PM in reply to: mzakiralam
This very basic code hope it will get you started,
add properties to our suit
		<CommandMethod("ptsRead")> _
		Public Sub testReadCSV()
			Dim filePath As String = "C:\Test\points.txt"
			If Not File.Exists(filePath) Then
				MessageBox.Show("File does not exist")
				Return
			Dim sep As String = ";"
			Dim pts As New Point3dCollection()
			Using reader As New System.IO.StreamReader(filePath)
				While Not reader.EndOfStream
					Dim textLine As String = reader.ReadLine()
					Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "{0}", textLine)
					Dim tmp As String() = textLine.Split(New String() {sep}, StringSplitOptions.RemoveEmptyEntries)
					If tmp.Length <> 0 Then
						Dim pt As New Point3d(Convert.ToDouble(tmp(0)), Convert.ToDouble(tmp(1)), Convert.ToDouble(tmp(2)))
						pts.Add(pt)
				End While
			End Using
			If pts Is Nothing Then
				MessageBox.Show("Cant parse this file")
				Return
			Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
			Dim db As Database = doc.Database
			Dim ed As Editor = doc.Editor
			Using tr As Transaction = db.TransactionManager.StartTransaction()
				Dim btr As BlockTableRecord = TryCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
				For Each pnt As Point3d In pts
					Dim pt As New DBPoint(pnt)
					pt.SetDatabaseDefaults()
					pt.ColorIndex = 121
					' <-- set any color of point
					btr.AppendEntity(pt)
					Dim txt As New DBText()
					tr.AddNewlyCreatedDBObject(pt, True)
					txt.SetDatabaseDefaults()
					txt.Position = pt.Position
					txt.TextString = txt.Position.ToString()
					'<-- add any textstring to suit
					txt.Justify = AttachmentPoint.BaseLeft
					' txt.AlignmentPoint = pt.Position;
					txt.AdjustAlignment(db)
					btr.AppendEntity(txt)
					tr.AddNewlyCreatedDBObject(txt, True)
				Next
				tr.Commit()
			End Using
		End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
mzakiralam
Message 3 of 3 (140 Views)
12-10-2012 12:21 AM in reply to: Hallex
Hi Hallex,
Thanks for your response. I will try it and let you know about the status.
Regards
Zakir
You are not logged in.
Announcements
Need installation help?
Ask the Community
