.NET
Extract Constant Attributes from Block Reference
3 REPLIES 3
LialAtArnold
414 Views, 3 Replies
I am trying to extract the text from the Constant attributes attached to a BlockReference.
I know I have to use a COM object.
The acadBlockRef returns a type System.Object.
How do I get to the attributes inside the AcadBlockReference???
The code is as follows:
foreach (ObjectId aID in dwgDeviceIds)
//Create a reference to the block and open it for reading
BlockReference myBR = (BlockReference)tm.GetObject(aID, OpenMode.ForRead);
if (myBR.Layer.Equals("PIDSYM"))
AcadBlockReference acadBlockRef = (AcadBlockReference) myBR.AcadObject;
??????? = acadBlockRef.GetConstantAttributes();
3 REPLIES 3
in reply to: LialAtArnold
You may have to use an Object array and then post process if you need it
cast differently.
{code}
Object[] Objs = acadBlockRef.GetConstantAttributes();
AcadAttribute[] Atts = new AcadAttribute[Objs.Length];
Objs.CopyTo(Atts, 0);
{code}
James Allen
Malicoat-Winslow Engineers, P.C.
Columbia, MO
Object[] objs =
(object[])acadBlockRef.GetConstantAttributes();
wrote in message
news:6242898@discussion.autodesk.com...
BlockReference.
OpenMode.ForRead);
myBR.AcadObject;
LialAtArnold
James and Paul,
Between the two responses I was finally able to get this to work.
Thanks for the help.
”Boost
