.NET
Active Member
hmshettikera
Message 1 of 7 (545 Views)
Extract BlockNames from autocad DWG file
545 Views, 6 Replies
07-10-2012 02:33 AM
1) Is it possible to extract data from dwf file in autocad 2012?
2)I need to extract blockNames from dwg file but i dont know how to extract blackNames because  text in dwg file may change but pattern will remain same.
I am using Visual studio 2010 and Autocad 2012
Board Manager
StephenPreston
Message 2 of 7 (500 Views)
Re: Extract BlockNames from autocad DWG file
07-11-2012 06:09 PM in reply to: hmshettikera
1. See www.autodesk.com/developdwf.
2. You'll find some related code here that shows how to find a block name - http://adndevblog.typepad.com/autocad/2012/05/identifying-block-name-from-the-block-reference.html. Probably not exactly what you want. If you're new to AutoCAD .NET development, visit www.autodesk.com/developautocad.
Cheers,
Stephen Preston
Autodesk Developer Network
Active Member
hmshettikera
Message 3 of 7 (447 Views)
07-23-2012 07:03 AM in reply to: StephenPreston
thanks for reply,
I  have a  blockName " UserName"  and i want to fetch this and insert into sql server
can any one tell be how to extract this blockname properties using .Net api in c#?
Hallex
Message 4 of 7 (432 Views)
07-23-2012 08:58 AM in reply to: hmshettikera
Try this code for selecting your blocks,
change list of tags in there
        [CommandMethod("ibsql", CommandFlags.Modal | CommandFlags.Session | CommandFlags.Transparent)]
        public void ImportDataTableToSQL()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            string ctab = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("ctab").ToString();
            System.Data.DataTable dt = new System.Data.DataTable();
            List<string> tags = new List<string>() { "TAG1", "TAG2", "TAG3", "TAG4" };
           using ( DocumentLock docklock = ed.Document.LockDocument())
            using (Transaction tr = db.TransactionManager.StartTransaction())
                try
                    BlockTable tb = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                    BlockTableRecord tbr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                    dt.TableName = "MyBlockTable";
                    dt.Columns.Add("BlockName", typeof(string));
                    dt.Columns.Add("Handle", typeof(string));
                    dt.Columns.Add("X_Coordinate", typeof(double));
                    dt.Columns.Add("Y_Coordinate", typeof(double));
                    dt.Columns.Add("Z_Coordinate", typeof(double));
                    // add columns for attributes
                    foreach (string tag in tags)
                        dt.Columns.Add(tag, typeof(string));
                    TypedValue[] values = { new TypedValue(0, "INSERT"),
                                              new TypedValue(66, 1),
                                              new TypedValue(410, ctab),
                                              new TypedValue(2, "UserName, `*U*") };
                    SelectionFilter filter = new SelectionFilter(values);
                    PromptSelectionResult res = ed.SelectAll(filter);
                    if (res.Status != PromptStatus.OK)  return;
                    SelectionSet sset = res.Value;
                    foreach (SelectedObject selobj in sset)
                        DBObject obj = (DBObject)tr.GetObject(selobj.ObjectId, OpenMode.ForRead);
                        BlockReference blk = obj as BlockReference;
                        string bname = string.Empty;
                        // get real block name
                        if (blk.IsDynamicBlock)
                            BlockTableRecord btrec = (BlockTableRecord)tr.GetObject(blk.DynamicBlockTableRecord, OpenMode.ForRead);
                            bname = btrec.Name;
                        else
                            BlockTableRecord btrec = (BlockTableRecord)tr.GetObject(blk.BlockTableRecord, OpenMode.ForRead);
                            bname = btrec.Name;
                        string hdl = blk.Handle.Value.ToString();
                        Point3d pt = blk.Position;
                        double xp = pt.X;
                        double yp = pt.Y;
                        double zp = pt.Z;
                        System.Data.DataRow dr = dt.NewRow();
                        dr[0] = bname;
                        dr[1] = hdl;
                        dr[2] = xp;
                        dr[3] = yp;
                        dr[4] = zp;
                        AttributeCollection attribs = blk.AttributeCollection;
                        int k = 5;
                        foreach (ObjectId attid in attribs)
                            AttributeReference attref = (AttributeReference)tr.GetObject(attid, OpenMode.ForRead);
                            dr[k] = attref.TextString;
                            k += 1;
                        dt.Rows.Add(dr);
                    //Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("At this point you can load this table on SQL Server");
                    // for debug only:
                    for (int i = 0; i < dt.Rows.Count; i++)
                        System.Data.DataRow dr = dt.Rows[i];
                        object[] rowarr = dr.ItemArray;
                        for (int j = 0; j < dt.Columns.Count; j++)
                            ed.WriteMessage("\n{0}\n",rowarr[j]);
                    tr.Commit();
                catch (System.Exception ex)
                    ed.WriteMessage("\n{0}\n{1}\n",ex.Message,ex.StackTrace);
                finally
                    dt.Dispose();
~'J'~
Active Member
hmshettikera
Message 5 of 7 (419 Views)
07-24-2012 01:11 AM in reply to: Hallex
Thanks for reply, i used your code but its displaying the  Alert message and even there is nothing in dt
can you look into my code? is it right?
            using (DocumentLock docklock = ed.Document.LockDocument())
                    try
                                bname = btrec.Name;
                            else
                                bname = btrec.Name;
                            double xp = pt.X;
                            double yp = pt.Y;
                            double zp = pt.Z;
                            dr[0] = bname;
                            dr[1] = hdl;
                            dr[2] = xp;
                            dr[3] = yp;
                            dr[4] = zp;
                       Autodesk.AutoCAD.DatabaseServices.AttributeCollection attribs = blk.AttributeCollection;
                            int k = 5;
                                k += 1;
                            dt.Rows.Add(dr);
                        // for debug only:
                                ed.WriteMessage("\n{0}\n", rowarr[j]);
                        tr.Commit();
                        ed.WriteMessage("\n{0}\n{1}\n", ex.Message, ex.StackTrace);
                    finally
//Here i am trying to display the record in datagridview but its NUll
                       dataGridView1.DataSource = dt.DefaultView;
                        Form1 form = new Form1();
                        form.Show();
                       dt.Dispose();
 And also can you help to list all blockNames with text ? show that i can filter this later...
ADN Support Specialist
Virupaksha.aithal
Message 6 of 7 (367 Views)
08-01-2012 04:22 AM in reply to: hmshettikera
Hi
As you have block name as “UserName”, can you please try with below filter?
                                  new TypedValue(2, "UserName") };
Virupaksha Aithal KM
Developer Technical Services
Hallex
Message 7 of 7 (362 Views)
08-01-2012 05:53 AM in reply to: hmshettikera
You have to declare Datatable in Form class as public:
public System.Data.DataTable dt = new System.Data.DataTable();
then add button to do your work AutoCAD
then on Form Initializing do your job with DatagridView, e.g. add columns etc,
then click button to go to AutoCAD,
hide form before,
then after the selection would be executed,
show Form,
display result in DataGridView,
somerhing along this way...
~'J'~
You are not logged in.
Ask the Community
