.NET
Alfred.NESWADBA
Message 11 of 16 (234 Views)
Re: Extract Bill of Materials
07-16-2012 09:20 AM in reply to: amitk_189
OK, now I understand (at least I hope so).
I did show you in my demo-project how you can access entities in modelspace using COM, so please try to get the text-objects by yourself based on what I showed you on how to loop through the modelspace, just don't use an ObjectID.
- alfred -
Alfred NESWADBA
amitk_189
Message 12 of 16 (233 Views)
07-16-2012 09:35 AM in reply to: Alfred.NESWADBA
Ok Thanks for Guiding me through out this project. I will try to get text objects and avoid objectID.
Probably if you find any ideas of solutions keep me posted on this.
With Warm Regards
Amit
Software Engineer
Hallex
Message 13 of 16 (224 Views)
07-16-2012 11:41 AM in reply to: amitk_189
This will get you started
       <System.Security.SuppressUnmanagedCodeSecurity()> _
        Public Shared Sub ReadTexts()
            ' Set application version ( I use 17 for A2009, 18 is for A2010)
            Dim acadver As String = "17"
            ' Set your file name to read  data here
            Dim fname As String = "C:\Test\tags.dwg"
            ' Define csv file name variable
            Dim csvname As String = String.Empty
            Dim listData As New List(Of Object)
            ' Get current culture
            Dim oldCult As System.Globalization.CultureInfo = System.Threading.Thread.CurrentThread.CurrentCulture
            ' Create new culture
            Dim thisCult As System.Globalization.CultureInfo = New System.Globalization.CultureInfo("en-US")
            ' Set current culture to newly created one
            System.Threading.Thread.CurrentThread.CurrentCulture = thisCult
            MsgBox("Wait...")
            Dim appProgID As String = "Autocad.Application" + "." + acadver
            ' Get reference on interface  IDispatch
            Dim AcadType As Type = Type.GetTypeFromProgID(appProgID)
            ' Run AutoCAD
            Dim AcadApp As Object = Activator.CreateInstance(AcadType)
            Dim visargs() As Object = New Object(0) {}
            ' Set visibility mode to true
            visargs(0) = True
            ' Make application visible
            AcadApp.GetType().InvokeMember("Visible", BindingFlags.SetProperty, Nothing, AcadApp, visargs, Nothing)
            ' Maximize window
            AcadApp.GetType().InvokeMember("WindowState", BindingFlags.SetProperty, Nothing, AcadApp, New Object() {3}, Nothing)
            Dim AcadDocs As Object = AcadApp.GetType().InvokeMember("Documents", BindingFlags.GetProperty, Nothing, AcadApp, Nothing)
            ' Define arguments to open file
            Dim args() As Object = New Object(1) {}
            args(0) = fname
            ' Set read only mode to true
            args(1) = False
            ' Try open document
            Dim AcDoc As Object = AcadDocs.GetType.InvokeMember("Open", BindingFlags.InvokeMethod, Nothing, AcadDocs, args, Nothing)
            'Try
            '    '' Set Try Catch block to avoid crash application
            '    '' if any items does not exists :
            '    Dim AcSuminfo As Object = AcDoc.GetType.InvokeMember("SummaryInfo", BindingFlags.GetProperty, Nothing, AcDoc, Nothing)
            '    Dim Author As Object = AcSuminfo.GetType.InvokeMember("Author", BindingFlags.GetProperty, Nothing, AcSuminfo, Nothing)
            '    Dim Comments As Object = AcSuminfo.GetType.InvokeMember("Comments", BindingFlags.GetProperty, Nothing, AcSuminfo, Nothing)
            '    Dim HyperlinkBase As Object = AcSuminfo.GetType.InvokeMember("HyperlinkBase", BindingFlags.GetProperty, Nothing, AcSuminfo, Nothing)
            '    Dim Keywords As Object = AcSuminfo.GetType.InvokeMember("Keywords", BindingFlags.GetProperty, Nothing, AcSuminfo, Nothing)
            '    Dim LastSavedBy As Object = AcSuminfo.GetType.InvokeMember("LastSavedBy", BindingFlags.GetProperty, Nothing, AcSuminfo, Nothing)
            '    Dim RevisionNumber As Object = AcSuminfo.GetType.InvokeMember("RevisionNumber", BindingFlags.GetProperty, Nothing, AcSuminfo, Nothing)
            '    Dim Subject As Object = AcSuminfo.GetType.InvokeMember("Subject", BindingFlags.GetProperty, Nothing, AcSuminfo, Nothing)
            '    Dim Title As Object = AcSuminfo.GetType.InvokeMember("Title", BindingFlags.GetProperty, Nothing, AcSuminfo, Nothing)
            '    ' Add and display standard properties
            '    MsgBox("The standard drawing properties are " & vbLf & _
            '           "Author = " & Author.ToString() & vbLf & _
            '           "Comments = " & Comments.ToString() & vbLf & _
            '           "HyperlinkBase = " & HyperlinkBase.ToString() & vbLf & _
            '           "Keywords = " & Keywords.ToString() & vbLf & _
            '           "LastSavedBy = " & LastSavedBy.ToString() & vbLf & _
            '           "RevisionNumber = " & RevisionNumber.ToString() & vbLf & _
            '           "Subject = " & Subject.ToString() & vbLf & _
            '           "Title = " & Title.ToString())
            'Catch
            'End Try
            Dim AcUtil As Object = New Object
            Try
                ' get reference on active document
                AcDoc = AcadApp.GetType.InvokeMember("ActiveDocument", BindingFlags.GetProperty, Nothing, AcadApp, Nothing, Nothing)
                ' Get reference on ModelSpace
                Dim AcSpace As Object = AcDoc.GetType.InvokeMember("ModelSpace", BindingFlags.GetProperty, Nothing, AcDoc, Nothing)
                ' get reference on Utility
                AcUtil = AcDoc.GetType.InvokeMember("Utility", BindingFlags.GetProperty, Nothing, AcDoc, Nothing, Nothing)
                ' get reference on SelectionSets
                Dim AcSsets As Object = AcDoc.GetType.InvokeMember("SelectionSets", BindingFlags.GetProperty, Nothing, AcDoc, Nothing, Nothing)
                ' Perform zooming
                AcadApp.GetType.InvokeMember("ZoomExtents", BindingFlags.InvokeMethod, Nothing, AcadApp, Nothing, Nothing)
                ' Perform zooming
                AcadApp.GetType.InvokeMember("ZoomScaled", BindingFlags.InvokeMethod, Nothing, AcadApp, New Object() {0.8, 1})
                ' Add prompt to the command line
                AcUtil.GetType.InvokeMember("Prompt", BindingFlags.InvokeMethod, Nothing, AcUtil, New Object() {vbLf & "  >>  SELECT TEXTS ON SCREEN >> "})
                ' Add SelectionSet, named "$SelectionTest$"
                AcSsets.GetType.InvokeMember("Add", BindingFlags.InvokeMethod, Nothing, AcSsets, New Object() {"$SelectionTest$"})
                ' Get reference on newly created Selection Set
                Dim AcSset As Object = AcSsets.GetType.InvokeMember("Item", BindingFlags.InvokeMethod Or BindingFlags.GetProperty, Nothing, AcSsets, New Object() {"$SelectionTest$"})
                ' Create filter to use attributed blocks
                Dim selargs As Object() = New Object(1) {}
                Dim ftype As Short() = New Short() {0}
                Dim fdata As Object() = New Object() {"*TEXT"}
                selargs(0) = DirectCast(ftype, Object)
                selargs(1) = DirectCast(fdata, Object)
                ' Perform selection on screen
                AcSset.GetType.InvokeMember("SelectOnScreen", BindingFlags.InvokeMethod, Nothing, AcSset, selargs)
                ' Get number of selected items
                Dim cnt As Integer = CInt(AcSset.GetType.InvokeMember("Count", BindingFlags.GetProperty, Nothing, AcSset, Nothing))
                AcUtil.GetType.InvokeMember("Prompt", BindingFlags.InvokeMethod, Nothing, AcUtil, New Object() {vbLf & "--> Selected Mtexts -->" & vbTab & cnt.ToString()})
                ' Loop through selected objects
                For n As Integer = 0 To cnt - 1
                    ' Get single item from selection
                    Dim AcSelItem As Object = AcSset.GetType.InvokeMember("Item", BindingFlags.InvokeMethod, Nothing, AcSset, New Object() {n})
                    ' Get Object name
                    Dim objName As String = AcSelItem.GetType.InvokeMember("ObjectName", BindingFlags.GetProperty, Nothing, AcSelItem, Nothing).ToString()
                    Dim textStr As String = String.Empty
                    If objName = "AcDbText" Then
                        textStr = AcSelItem.GetType.InvokeMember("TextString", BindingFlags.GetProperty, Nothing, AcSelItem, Nothing).ToString()
                    ElseIf objName = "AcDbMText" Then
                    End If
                    listData.Add(textStr)
                Next
                Dim initDir As String = AcDoc.GetType.InvokeMember("Path", BindingFlags.GetProperty, Nothing, AcDoc, Nothing, Nothing).ToString()
                Dim saveFileDialog As New System.Windows.Forms.SaveFileDialog
                saveFileDialog.Title = "Enter a file name to write data: "
                saveFileDialog.InitialDirectory = initDir
                saveFileDialog.RestoreDirectory = True
                saveFileDialog.Filter = "CSV files | *.csv"
                saveFileDialog.FileName = "File name without extension"
                Dim result As System.Windows.Forms.DialogResult = saveFileDialog.ShowDialog()
                If result <> DialogResult.OK Then
                    csvname = "Not saved"
                    Return
                End If
                csvname = saveFileDialog.FileName
                ' Write data
                Using sw As New StreamWriter(csvname, True, Encoding.ASCII)
                    For Each strline As String In listData
                        sw.WriteLine(strline)
                    Next
                    sw.Flush()
                    sw.Close()
                End Using
                'Save document
                Dim closeargs() As Object = New Object(1) {}
                closeargs(0) = True
                ' with the same name
                closeargs(1) = fname
                ' Try close document
                ' Simplified syntax
                AcDoc.GetType().InvokeMember("Close", BindingFlags.InvokeMethod, Nothing, AcDoc, closeargs)
                ' Try quit application
                AcadApp.GetType().InvokeMember("Quit", BindingFlags.InvokeMethod, Nothing, AcadApp, Nothing)
            Catch ex As System.Exception
                MsgBox("Error: " & ex.Message & vbLf & "Trace: " & ex.StackTrace)
            Finally
                ' clean up the memory
                ' release Utility.
                releaseObject(AcUtil)
                ' release Document.
                releaseObject(AcDoc)
                ' release Documents.
                releaseObject(AcadDocs)
                ' release Application.
                releaseObject(AcadApp)
                ' call garbage cleaner immediatelly
                GC.WaitForPendingFinalizers()
                GC.GetTotalMemory(True)
                ' restore current culture
                System.Threading.Thread.CurrentThread.CurrentUICulture = oldCult
                'Display result
                MsgBox("Csv file saved as : " + csvname)
            End Try
        End Sub
        Public Shared Sub releaseObject(ByVal obj As Object)
            Try
                System.Runtime.InteropServices.Marshal.FinalReleaseComObject(obj)
                obj = Nothing
                obj = Nothing
            Finally
                GC.Collect()
            End Try
        End Sub
~'J'~
amitk_189
Message 14 of 16 (212 Views)
07-16-2012 07:05 PM in reply to: Alfred.NESWADBA
Yes, It Worked. Thanks a Lot Hallex. Thankyou very Much Hallex for Supporting Me. Thanks a Lot.
Thanks Alfred Neswadba for Guiding me. Thanks a Lot
Thank You
With Warm Regards
Amit
Software Engineer
Hallex
Message 15 of 16 (203 Views)
07-16-2012 09:17 PM in reply to: amitk_189
Glad to help
cheers  :smileyhappy:
~'J'~
amitk_189
Message 16 of 16 (174 Views)
07-24-2012 03:21 AM in reply to: Hallex
Is it possible to use select All option instead of selecting/prompting user to select on screen but hide autocad (donot display)
