.NET
amitk_189
Message 1 of 16 (500 Views)
Extract Bill of Materials
500 Views, 15 Replies
07-14-2012 03:56 AM
Hello There, I am doing a project where am required to open AutoCAD Database and Extract Data from AutoCAD.
I am using VB.Net as Front End.
I am not using NetLoad.
Directly i am opening the AutoCAD Drawing and trying to access the data.
But all my attempts are unsuccessful anybody has solution
acadApp = CreateObject("AutoCAD.Application")
acadApp.Visible = False
Dim ValCount As Integer = 0
'acadDoc = acadApp.Documents.Open(Files(ValCount), True, Type.Missing)
acadApp.Documents.Open("C:\SomeDwg.dwg", True, Type.Missing)
acadApp.Visible=false
Now using acadApp i am trying to extract Data as AcadApp has AutoCAD Drawing
Can you Guide me, on how to solve this
Alfred.NESWADBA
Message 2 of 16 (481 Views)
Re: Extract Bill of Materials
07-14-2012 01:05 PM in reply to: amitk_189
So you get an error message? Or what attemts did you try and how did they fail?
The question following to that is: what do you want to extract? BlockReferences, containing attributes or text-objects or titleblock-information or polylines or ....?
- alfred -
Alfred NESWADBA
amitk_189
Message 3 of 16 (459 Views)
07-15-2012 05:17 AM in reply to: Alfred.NESWADBA
Dim progID As String = "AutoCAD.Application"
Try
acadApp = GetObject(progID)
Catch ex As Exception
Try
Dim acType As Type = GetTypeFromProgID(progID)
acadApp = Activator.CreateInstance(acType, True)
acadApp.Documents.Open(Files(0), True, Type.Missing)
acadDoc = acadApp.ActiveDocument.Database
acadDB = acadDoc.Database
Catch exx As Exception
End Try
Here i launch a autoCAD instance and open a document files(0). Files(0) is an array which has 100 drawings and i am selecting first one.
Now in this below i am trying to open the autocad database and extract information which is MText or Text.
Can you  Guide me
Author = acadDB.SummaryInfo.Author
FullName = acadDB.Filename
Version = System.Enum.GetName(GetType(Autodesk.AutoCAD.DatabaseServices.DwgVersion), acadDB.LastSavedAsVersion)
Dim myDwgIO As New IO.FileInfo(acadDB.Filename)
If myDwgIO.Exists Then
Nameee = myDwgIO.Name
LastSaved = myDwgIO.LastWriteTime
Sizeee = myDwgIO.Length
End If
Using myTrans As Transaction = acadDB.TransactionManager.StartTransaction
Dim myBT As BlockTable = acadDB.BlockTableId.GetObject(OpenMode.ForRead)
Dim myModelSpace As BlockTableRecord = myBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForRead)
For Each myObjID As ObjectId In myModelSpace
Dim myEnt As Entity = myObjID.GetObject(OpenMode.ForRead)
If TypeOf myEnt Is DBText Then
Dim myText As DBText = myEnt
Dim myExtText As New extractText
'Dim myExtTextPosition As New extractText
myExtText.Handle = myText.Handle.ToString
myExtText.Layer = myText.Layer
myExtText.Position = myText.Position
myExtText.TextString = myText.TextString
Texts.Add(myExtText)
Sample.Add(myText.TextString)
ElseIf TypeOf myEnt Is MText Then
Dim urText As MText = myEnt
Dim urExtText As New extractText
urExtText.Handle = urText.Handle.ToString
urExtText.Layer = urText.Layer
'urExtText.Position = urText.Position
'urExtText.TextString = urText.textString
Texts.Add(urExtText)
Dim aaaa As String = urText.Text
Sample.Add(urText.Text)
End If
Next
End Using
The error I get is cannot open acadDB. My aim is to open database and get Texts and i am using the this above method
Can you provide me some solutions or some suggestions on how to solve this.
Regards
Amit
Alfred.NESWADBA
Message 4 of 16 (446 Views)
07-15-2012 08:50 AM in reply to: amitk_189
in your first part there is at least one "End Try" missing :smileywink:
To your global procedure: If you use an EXE and start AutoCAD using the ActiveX/COM-Interface you cannot mix it up with managed-access. ObjectID, TransAction, .... all that could only be used within DLL's that are NETLOADed or loaded with the plugin-functionality.
Next point to that code:
....the orange part is wrong. If you work with option strict on you would have seen that as type-conflict.
And to scan the ModelSpace now can be done in that way:
   Dim tEnt as AcadEntity
   For each tEnt in AcadDB.ModelSpace
   Next
HTH, - alfred -
Alfred NESWADBA
amitk_189
Message 5 of 16 (425 Views)
07-15-2012 11:32 PM in reply to: amitk_189
But i am opening AutoCAD at Background, only difference is the visibility is false. So is it possible to execute like that.
AutoCAD is open at background and can we run the code for accessing database
Or else is it possible to access the Working Database of already Opened AutoCAD Drawing. Like we have HostApplicationServices.WorkingDatabase
Am stuck up here: HostApplicationServices.WorkingDatabase
Now am trying to Connect to this using the created instance of AutoCAD
amitk_189
Message 6 of 16 (405 Views)
07-16-2012 02:38 AM in reply to: amitk_189
But There might be some or other way to access the Database services of AutoCAD using AutoCAD Instance, because the application which i am developing runs outside autocad using Its instance not using Netload
Alfred.NESWADBA
Message 7 of 16 (398 Views)
07-16-2012 03:37 AM in reply to: amitk_189
You can access AutoCAD-drawings from outside AutoCAD, but as you wrote that you don't have a DLL and you don't start _NETLOAD to load a managed DLL you can't have managed access/functions working.
You can access AutoCAD-drawings by using the ActiveX/COM functionality. So you can start AutoCAD e.g. with CreateObject(,"AutoCAD.Application"), you can then access the current drawing with .ActiveDocument and you can scan the modelspace (or other drawing-internals) then.
That you did open the application using .Visible = False has nothing to do with accessing it with managed or with COM-functionality.
Again, as long as you don't create a DLL that could be loaded with _NETLOAD you can't use the managed functions.
Find attached a sample that starts or connects to AutoCAD, opens a drawing and scans the modelspace, it's not tested, it's just written to give you a way.
- alfred -
Alfred NESWADBA
amitk_189
Message 8 of 16 (390 Views)
07-16-2012 05:27 AM in reply to: Alfred.NESWADBA
Yes it worked, as per expectations but when i try to alter the code to meet my expectations it gives error.
I am sending my copy of code have a look at it.
I am working on it and trying to incorporate your logic, Can you make some changes and Test
On Netload open the Drawing in Folder
Alfred.NESWADBA
Message 9 of 16 (378 Views)
07-16-2012 07:19 AM in reply to: amitk_189
??? What is your goal now?
In your first messages you wrote that you create an EXE and you don't use _NETLOAD.
Now you sent a project that creates a DLL and I should do a _NETLOAD. For that case now my previous sample is irrelevant as it is a demo-project for how to control AutoCAD from an external EXE.
Back to your DLL now. I updated the references (2 managed and 2 interops) started AutoCAD in debug-mode, _NETLOADed the DLL, started command "TESTING" and got this dialog.
I don't know it that dialog is ok or not. It starts, it does not make any exception, it shows a dialog with some values in it .... what's wrong then? I can search for a problem, but I don't see any or you have not pointed me to your problem clearly enough.
- alfred -
Alfred NESWADBA
amitk_189
Message 10 of 16 (375 Views)
07-16-2012 07:36 AM in reply to: amitk_189
Earlier i did like this. But now the same thing i am required to extract using standard exe using Instance of AutoCAD.  This is Netload One. But now we are required to eliminate this option and using standard Exe we have to get this
The data which is displayed is the WindowsForm. I am trying to get this but not been able to do this.
Regards
Amit
You are not logged in.
Ask the Community
