.NET
Export to WMF without using Interop
9 REPLIES 9
Message 1 of 10
karea
1818 Views, 9 Replies
Hi:
I would like to export a DWG file to WMF. I've read in the forum I need to add Autodesk.Autocad.interop.dll and Autodesk.Autocad.interop.common.dll, but with these references the interface displays too many duplicate definitions.
How can I do without using Interop references?
thanks,
9 REPLIES 9
Message 2 of 10
_gile
in reply to: karea
You can use the 'dynamic' type (Framwork4 / A2012+) or late binding with reflection with prior versions.
The main inconvenient is that you won't have help from Visual Studio at editing and compiling time (intellisense). If there's an error in the code (i.e. a typo in a method or property or a bad argument type) the exception will raise at runnig time.
To avoid writing every time: "GetType().InvokeMember("membername", blah blah blah )" with late binding, you can use some extension methods which make the code more legible, there're many examples, here's one:
using BF = System.Reflection.BindingFlags;
namespace LateBindingHelpers
    public static class LateBinding
        public static object GetInstance(string appName)
            return System.Runtime.InteropServices.Marshal.GetActiveObject(appName);
        public static object CreateInstance(string appName)
            return System.Activator.CreateInstance(System.Type.GetTypeFromProgID(appName));
        public static object GetOrCreateInstance(string appName)
            try { return GetInstance(appName); }
            catch { return CreateInstance(appName); }
public static void ReleaseInstance(this object obj)
System.Runtime.InteropServices.Marshal.ReleaseComObject(obj);
} public static object Get(this object obj, string propName, params object[] parameter) { return obj.GetType().InvokeMember(propName, BF.GetProperty, null, obj, parameter); } public static void Set(this object obj, string propName, params object[] parameter) { obj.GetType().InvokeMember(propName, BF.SetProperty, null, obj, parameter); } public static object Invoke(this object obj, string methName, params object[] parameter) { return obj.GetType().InvokeMember(methName, BF.InvokeMethod, null, obj, parameter); } } }
Gilles Chanteau
GileCAD
GitHub
Message 3 of 10
karea
in reply to: _gile
than you Gille,
I'm working with VB.NET but I will try to translete the code to VB.NET.
Now, I would like to export the drawing to WMF but I'm not able to use the export command,..
Message 4 of 10
_gile
in reply to: _gile
Using examples.
With late binding extension methods
        [CommandMethod("ExportWmf", CommandFlags.Modal)]
        public void ExportWmf()
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptSelectionResult psr = ed.GetSelection();
            if (psr.Status != PromptStatus.OK)
                return;
            object acadDoc = doc.AcadDocument; // replace with doc.Getacaddocument() for A2013+
            object selSet = acadDoc.Get("ActiveSelectionSet");
            acadDoc.Invoke(
                "Export",
                System.IO.Path.ChangeExtension(db.Filename, "wmf"),
                "wmf",
                selSet);
            selSet.Invoke("Delete");
With dynamic type
                return;
            dynamic acadDoc = doc.AcadDocument; // replace with doc.Getacaddocument() for A2013+
            dynamic selSet = acadDoc.ActiveSelectionSet;
            acadDoc.Export(
                "wmf",
                selSet);
            selSet.Delete();
Gilles Chanteau
GileCAD
GitHub
Message 5 of 10
_gile
in reply to: karea
Sorry,
VB.net doesn't allow  using extension methods with the Object type. But, if you set the Strict option to Off (default), VB.net uses implicitly late binding for the Object type.
So, you can write your code as if you referenced AutoCAD.Interop with replacing interop types with Object.
        <CommandMethod("ExportWmf")> _
        Public Sub ExportWmf()
            Dim doc As Document = AcApp.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim psr As PromptSelectionResult = ed.GetSelection()
            If psr.Status <> PromptStatus.OK Then
                Return
            End If
' replace with doc.GetAcadDocument() for A2013+ Dim acadDoc As Object = doc.AcadDocument Dim selSet As Object = acadDoc.ActiveSelectionSet acadDoc.Export( _ System.IO.Path.ChangeExtension(db.Filename, "wmf"), _ "wmf", _ selSet) selSet.Delete() End Sub
Gilles Chanteau
GileCAD
GitHub
Message 6 of 10
karea
in reply to: karea
hi,
The code you send is ok to use like command in a single drawing but I would like to use in batch process and when I execute the code appears "InvalidCastException" and it no runs.
thanks for your answer!,
Message 7 of 10
_gile
in reply to: karea
For a batch process, as you need to open the drawing in the editor for a selection, you cannot use Database.ReadDwgFile() method.
Here's a quick and dirty (no error handling) which shows a way to open each selected dwg into the current session.
        <CommandMethod("ExportWmf", CommandFlags.Session)> _
            Dim docMan As DocumentCollection = AcApp.DocumentManager
            Dim fileDlg As OpenFileDialog = New OpenFileDialog()
            fileDlg.Filter = "Drawing (*.dwg)|*.dwg"
            fileDlg.Multiselect = True
            If fileDlg.ShowDialog = DialogResult.OK Then
                For Each filename As String In fileDlg.FileNames
                    Dim doc As Document = docMan.Open(filename)
                    ExportDocument(doc, filename)
                    doc.CloseAndDiscard()
                Next
            End If
        End Sub
        Private Sub ExportDocument(ByVal doc As Document, ByRef filename As String)
            Using doc.LockDocument()
                Dim acad As Object = AcApp.AcadApplication
                db.TileMode = True
                acad.ZoomExtents()
                Dim psr As PromptSelectionResult = ed.SelectAll()
                    Return
                End If
                acadDoc.Export( _
                    Path.Combine(Path.GetDirectoryName(filename), Path.GetFileNameWithoutExtension(filename)), _
                    "wmf", _
                    selSet)
                selSet.Delete()
            End Using
        End Sub
Gilles Chanteau
GileCAD
GitHub
Message 8 of 10
karea
in reply to: karea
When I was trying the code , two errors have appeared:
+ With  Dim acadDoc As Object = doc.AcadDocument :  'AcadDocument' is not a member of 'Autodesk.AutoCAD.ApplicationServices.Document'
+ Dim psr As PromptSelectionResult = ed.SelectAll() : Error eNotApplicable.
If I execute Dim psr As PromptSelectionResult = Application.DocumentManager.MdiActiveDocument.editor.SelectAll() the sentece runs.
Message 9 of 10
_gile
in reply to: karea
With AutoCAD 2013 (and 2014) the Document.AcadDocument property have been replaced by the DocumentExtension.GetAcadDocument() method.
This code seems to work for me (A2014).
                    Dim doc As Document = docMan.Open(filename, True)
                    Dim name As String = Path.Combine( _
                        Path.GetDirectoryName(filename), _
                        Dim acadDoc As Object = doc.GetAcadDocument()
                        db.TileMode = True
                        acad.ZoomExtents()
                            Return
                        End If
                        acadDoc.Export(name, "wmf", selSet)
                        selSet.Delete()
                    End Using
                Next
            End If
        End Sub
Gilles Chanteau
GileCAD
GitHub
Message 10 of 10
karea
in reply to: _gile
great!  it runs!
The code has a little problem with this sentence:
Because it appears an error 'eNotApplicable'
Instead of this I put:
Dim psr As PromptSelectionResult = Application.DocumentManager.MdiActiveDocument.Editor.SelectAll()
and it's ok,
thanks,
”Boost
