.NET
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Export pdf from VB.net
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
I'm trying to make an application that would take a drawing(dwg) and convert it to pdf. Since I can do it directly in autocad 2013, i presume that there should be a function in the API, that i could use to do the same. So far, i tried with AcadDocument.export(filename, FileExtension, AcadSelectionSet) with no luck. I cannot put PDF as a valid file extension.
Here's my code
Public sub SaveToPDF(ByVal psfilename As String)
Dim oAutocad As AutoCAD.AcadApplication = New AutoCAD.AcadApplication()
Dim oAcadDoc As AutoCAD.AcadDocument = oAutocad.Documents.Open(psfilename, True)
Dim sFolder As String = psfilename.Substring(0, psfilename.LastIndexOf("\") + 1)
Dim sFilename As String = psfilename.Substring(psfilename.LastIndexOf("\") + 1, (psfilename.Length - psfilename.LastIndexOf("\")) - (psfilename.Length - psfilename.LastIndexOf(".") + 1))
Dim oSS As AcadSelectionSet = Nothing
Try oSS = oAutocad.ActiveDocument.SelectionSets.Add("MySet")
oSS.Select(AcSelect.acSelectionSetAll)
oAutocad.ActiveDocument.Export(sFolder & sFilename & ".pdf", ".pdf", oSS)
oSS.Delete() Catch ex As Exception success = False oSS.Delete()
oSS = Nothing
End Try
For Each Doc In oAutocad.Documents
Doc.Close(False)
Next
oAutocad.Quit()
oAutocad = Nothing
end sub
Does anyone have an idea?
Re: Export pdf from VB.net
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
you will have to go through the plot-functionality using the "DWG to PDF.pc3"
That makes also more sense for setting the page-size you like to have as result.
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
See if this helps
Imports System.IO
<CommandMethod("pdfing")> _
Public Sub TestPDF()
SaveToPDF("C:\Test\blah.dwg")
End Sub
Public Sub SaveToPDF(ByVal psfilename As String)
Dim oAutocad As AcadApplication = New AcadApplication
oAutocad.Visible = True
oAutocad.WindowState = AcWindowState.acMax
Dim success As Boolean = False
Dim oAcadDoc As AcadDocument = oAutocad.Documents.Open(psfilename, False, "")
'Dim sFolder As String = Path.GetDirectoryName(psfilename) 'psfilename.Substring(0, psfilename.LastIndexOf("\") + 1)
'Dim sFilename As String = Path.GetFileNameWithoutExtension(psfilename) 'psfilename.Substring(psfilename.LastIndexOf("\") + 1, (psfilename.Length - psfilename.LastIndexOf("\")) - (psfilename.Length - psfilename.LastIndexOf(".") + 1))
Try
Dim ftype(0) As Short
ftype(0) = 410
Dim fdata(0) As Object
fdata(0) = "Model"
oAutocad.ZoomExtents()
oSS = oAcadDoc.SelectionSets.Add("MySet")
oSS.Select(AcSelect.acSelectionSetAll, Nothing, Nothing, ftype, fdata)
CreatePDF(oAcadDoc)
If oAcadDoc.Saved Then
oAcadDoc.Close(False)
End If
oAcadDoc = Nothing
oAutocad.Quit()
oAutocad = Nothing
success = True
MsgBox(ex.Message + vbLf + ex.StackTrace)
success = False
Finally
MsgBox(vbLf + "Program ended up with result of: " + success.ToString)
End Try
End Sub
Sub CreatePDF(acDoc As AcadDocument) 'by RBell
Dim PtConfigs As AcadPlotConfigurations
Dim PlotConfig As AcadPlotConfiguration
Dim PtObj As AcadPlot
Dim BackPlot As Object
'Create a new plot configutrarion with all needed parameters
PtObj = acDoc.Plot
PtConfigs = acDoc.PlotConfigurations
'Add a new plot configuration
PtConfigs.Add("PDF", False)
'The plot config you created become active
PlotConfig = PtConfigs.Item("PDF")
'Use this method to set the scale
PlotConfig.StandardScale = AcPlotScale.acScaleToFit
'Updates the plot
PlotConfig.RefreshPlotDeviceInfo()
'Here you specify the pc3 file you want to use
PlotConfig.ConfigName = "DWG To PDF.pc3"
'You can select the plot style table here
PlotConfig.StyleSheet = "acad.ctb"
'Specifies whether or not to plot using the plot styles
PlotConfig.PlotWithPlotStyles = True
'If you are going to create pdf files in a batch mode,
'I would recommend to turn off the BACKGROUNDPLOT system variable,
'so autocad will not continue to do anything until finishes
'the pdf creation
BackPlot = acDoc.GetVariable("BACKGROUNDPLOT")
acDoc.SetVariable("BACKGROUNDPLOT", 0)
'Updates the plot
''Acad.ActiveDocument.ActiveLayout.CopyFrom(plotco nfig)
'Now you can use the PlotTofile method
If PtObj.PlotToFile(Replace(acDoc.FullName, "dwg", "pdf"), PlotConfig.ConfigName) Then
acDoc.Utility.Prompt(vbLf + "PDF Was Created")
Else
acDoc.Utility.Prompt(vbLf + "PDF Creation Unsuccessful")
End If
'If you wish you can delete th plot configuration you created
'programmatically, and set the 'BACKGROUNDPLOT' system variable
'to its original status.
PtConfigs.Item("PDF").Delete()
PlotConfig = Nothing
acDoc.SetVariable("BACKGROUNDPLOT", BackPlot)
End Sub
~'J'~
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks guys
I've been able to convert my drawing in a pdf. The next step is turning my application into a windows service. i'm not able to start autocad. I see the process comming up in task manager but the next line ain't executed. Is there a way to open autocad in a windows service application?
Andre
