Execute code
Execute code
Execute code
Hi...
I wish that when I load a DLL into AutoCAD running a code, but if I load in another document also it run.
I've tried with Initialize and Terminate but it does not work:
Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
Public Sub Initialize() Implements IExtensionApplication.Initialize
End Sub
Public Sub Terminate() Implements IExtensionApplication.Terminate
End Sub
how I can do it?
Thanks you
You may want to look into events raised by
DocumentCollection, such as DocumentBecameCurrent/DocumentActivated... You would
place code into appropriate event handler to get it run when a document becomes
active or current (make sure you correctly understand the difference between
DocumentBecameCurrent and DocumentActivated...lots of try-and-see would help you
to decide whatevent you want to handle).
Hi...
another document also it run. I've tried with Initialize and Terminate but it
does not work: Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
Public Sub Initialize() Implements IExtensionApplication.Initialize ... End
Sub Public Sub Terminate() Implements IExtensionApplication.Terminate ... End
Sub how I can do it? Thanks you
Ok... But, Do you have an example?, please...
Thanks you
Off my head, here is some quick code (not tested,
not written in VS, so could be wrong):
namespce MySpance
    public class MyClass:
        static
DocumentColelction mDwgManager=null;
        public void
Initialize()
    //I alway put try...catch block, just in casesomething
unexpected occurs
    try
mDwgManager=Application.DocumentManager;
        //Handle DocumentBecameCurrent event,
which might be the most suitable to your requirement
        //But you may also want to try different
events based on your need
        mDwgManager,DocumentBecameCurrent+=new
DocumentCollectionEventHandler(MyDoucment_BecameCurrent)
    catch
        //Do something if necessary
        //Handle
event
        private
static void MyDocument_BecameCurrent(object sender, DocumentCollectionEventArgs
e)
    //Get the current document
    Document dwg=e.Document
    //You can also simply do this:
    //Document dwg=mDwgManager.MdiActiveDocument
    //Now that you have obtained the current drawing, which is
active, you can run code against it
    DoProcess(dwg);
HTH.
Ok...
But, Do you have an example?, please... Thanks you
