.NET
Exception during GetPoint function
3 REPLIES 3
415 Views, 3 Replies
I've aded this event
ed.PointFilter += new Autodesk.AutoCAD.EditorInput.PointFilterEventHandler(psRoomConnector_PointFilter);
and than call this function
Autodesk.AutoCAD.EditorInput.PromptPointResult ppr = ed.GetPoint(ppo);
psRoomConnector_PointFilter function generates Exception. If exception is generated than GetPoint finction doesn't finish correctly and autocad get in some undetermined state.
How to cancel getPoint function if exception was generated? or how to solve this situation?
3 REPLIES 3
{quote}
{quote}
Are you asking us to guess why it is throwing an error?
I don't think anyone can help you because we can't guess
what your code is doing wrong.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6269306@discussion.autodesk.com...
this situation?
No, I'm asking how to cancel getPoint function.
In other words if I start GetPoint function and than press Esc in Autocad, this function will be terminated. How to do it in C#? Edited by: ViaVitae on Oct 10, 2009 10:05 AM
There's no way to cancel a GetPoint() other than by sending ^C/ESCape to the
command line.
wrote in message news:6269312@discussion.autodesk.com...
”Boost
