Events Question
Events Question
Amremad
Events Question
Amremad
What's is deferent between the next two code
    Private Shared WithEvents docEvents As DocumentCollection
    Private Shared Sub docEvents_DocumentDestroyed(sender As Object, e As DocumentDestroyedEventArgs) Handles docEvents.DocumentDestroyed
        MsgBox(e.FileName & " docEvents_DocumentDestroyed")
    End Sub
    <CommandMethod("StartEventHandling")> _
    Public Sub Asdkcmd()
        docEvents = Application.DocumentManager
    End Sub
 and
Private Shared docDestroyedEvent As DocumentDestroyedEventHandler
    Public Shared Sub OnDocumentDestroyed(ByVal sender As Object, ByVal e As DocumentDestroyedEventArgs)
        MsgBox(e.FileName & " OnDocumentDestroyed")
    End Sub
        Dim docs As DocumentCollection = Application.DocumentManager
        If docDestroyedEvent Is Nothing Then
            docDestroyedEvent = New DocumentDestroyedEventHandler(AddressOf OnDocumentDestroyed)
            AddHandler docs.DocumentDestroyed, docDestroyedEvent
    End Sub
and what's the best for use
Amremad
jeff
Have you looked at documentation for WithEvents?
http://msdn.microsoft.com/en-us/library/aty3352y(v=vs.100).aspx
You can also find your answers @ TheSwamp
