Event handler triggered multiple times
SRSDS
Advisor Advisor
SRSDS
I have a SelectionAdded event handler that reacts three times when selecing a single block and once when deselecting it.
If there are two blocks in the drawing but only selected one it reacts 5 or 6 times.
And it reacts every time I pass the mouse over the selected block.
Is there any way to sidestep the events in the handler so that AutoCAD doesn't grind to a halt if I have multiple blocks in the drawing. And decide to move my mouse over all of them?
You have to add a event handler for it fire.
Maybe showing your code how you add them would help someone help you out.
SRSDS
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports AcApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.EditorInput
<Assembly: ExtensionApplication(GetType(VbExtApp))>
Public Class VbExtApp
    Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
    Private DocMan As DocumentCollection
    'Initialize sub
    Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
        DocMan = AcApp.DocumentManager
        AddHandler DocMan.DocumentCreated, AddressOf callback_documentCreated
        AddHandler DocMan.DocumentActivated, AddressOf callback_documentActivated
        Dim doc As Document
        For Each doc In DocMan
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            AddHandler db.ObjectModified, AddressOf callback_ObjectModified
            AddHandler db.ObjectAppended, AddressOf callback_ObjectAppended
            AddHandler db.ObjectErased, AddressOf callback_ObjectErased
            AddHandler ed.SelectionAdded, AddressOf callback_SelectionAdded
            ' AddHandler ed.SelectionRemoved, AddressOf callback_SelectionRemoved
        Next
        'Import Blocks
        ImportBlocks("D:\My Documents\Visual Studio Projects\Detailer\Blocks.dwg")
        'Load Palette
        Loading = True
        pal = New Palette()
        pal.LoadPalette()
        Loading = False
        'Initialise Thumbnail Class
        Dim thumb As ThumbNailClass
        thumb = New ThumbNailClass
    End Sub
    'SelectionAdded
    Public Sub callback_SelectionAdded(ByVal sender As System.Object, ByVal e As Autodesk.AutoCAD.EditorInput.SelectionAddedEventArgs)
        'MsgBox("Selection Made")
        For Each objid As ObjectId In e.AddedObjects.GetObjectIds
            ID = objid
            ReDim Preserve ObjectCollection(0)
            ReDim Preserve ObjectCollection(0).Set_(0)
            ReDim Preserve ObjectCollection(0).Set_(0).View(0)
            ReDim Preserve ObjectCollection(0).Set_(0).Range(0)
            ReDim Preserve ObjectCollection(0).Set_(0).Label(0)
            NoViews = 0 : NoRanges = 0 : NoLabels = 0
            ObjectsSelected()
        Next
    End Sub
    'Terminate sub
    Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
        RemoveHandler DocMan.DocumentCreated, AddressOf callback_documentCreated
    End Sub
    Public Shared Sub callback_ObjectModified(ByVal sender As System.Object, ByVal e As Autodesk.AutoCAD.DatabaseServices.ObjectEventArgs)
        'MsgBox("Something was modified")
        ID = e.DBObject.ObjectId
        ModifyEventHander()
    End Sub
    Public Shared Sub callback_ObjectAppended(ByVal sender As System.Object, ByVal e As Autodesk.AutoCAD.DatabaseServices.ObjectEventArgs)
        'MsgBox("Something was Appended")
    End Sub
    Public Shared Sub callback_ObjectErased(ByVal sender As System.Object, ByVal e As Autodesk.AutoCAD.DatabaseServices.ObjectErasedEventArgs)
        'MsgBox("Something was Erased")
        DeleteEventHandler()
    End Sub
    Private Sub callback_documentCreated(ByVal sender As Object, ByVal e As DocumentCollectionEventArgs)
        If e.Document = Nothing Then
            Exit Sub
        Else
            '   MsgBox("Document Created")
    End Sub
    Private Sub callback_documentActivated(ByVal sender As Object, ByVal e As DocumentCollectionEventArgs)
            Exit Sub
        Else
            '    MsgBox("Document Active")
    End Sub
End Class
SRSDS
I just added break points on the ObjectModified and ObjectAppended to see which event was triggering it.
On starting the debug  they were triggered an enless number of times.
Computers are fast these days but I don't want my application to slow things down.
Are there any step overs I should be considering in my code to handle these multiple fire events?
SRSDS
This is all very confusing.
If I press Escape with objects selected the SelectionAdded event handler is triggered containing the selection instead of the SelectionRemoved.
Is there a handler that deals with the current selection which reacts after any objects are added or removed?
SRSDS
Took a while but I found my answer here.
http://forums.autodesk.com/t5/NET/Emulate-Properties-Dialog-by-selecting-object-on-screen/td-p/25267...
I needed the ImpliedSelectionChanged event
AddHandler doc.ImpliedSelectionChanged, AddressOf Document_ImpliedSelectionChanged
    Private Sub Document_ImpliedSelectionChanged(ByVal sender As [Object], ByVal e As EventArgs)
        Dim doc As Document = DirectCast(sender, Document)
        Dim sr As PromptSelectionResult = ed.SelectImplied()
        If sr.Value Is Nothing Then
            Return
        ed.WriteMessage(vbLf & "Selection Count: {0}", sr.Value.Count)
    End Sub
