.NET
Error reading Dictionary "Object reference not set to an instance of an object"
5 REPLIES 5
SRSDS
554 Views, 5 Replies
Can anyone please explain what is going wrong here.
I'm getting a "NullReferenceException. Object reference not set to an instance of an object" using:
    For Each SetEntry As DBDictionaryEntry In SetRootDict
        Dim SetEntryDict As DBDictionary = CType(SetEntry.Value.GetObject(OpenMode.ForRead), DBDictionary)
    Next
I have the same lines letter for letter in a different procedure and referring the same unchanged root dictionary where it works fine.
5 REPLIES 5
SRSDS
in reply to: SRSDS
I replaced it with an alternative that works.
Dim SetEntryDict As DBDictionary = trans.GetObject(SetRootDict.GetAt(SetEntry.Key), OpenMode.ForRead)
A bit confused why the previous line would work in one location and not another.
jeff
in reply to: SRSDS
Was one inside a transaction and the other not?
If not When TopTransaction is called it might cause that.
You can also find your answers @ TheSwamp
SRSDS
in reply to: jeff
Hi Jeff,
Both are located inside the top transaction. I think this is relevant but the only difference I see is that the one that didn't work  was being called from an override. Probably not it though, just taking a wild stab.
jeff
in reply to: SRSDS
Override in a overrule?
If in a overrule's check out Stephen Preston's classes on it and if I remember correctly he suggests using OpenCloseTransactions
SRSDS
in reply to: jeff
Sorry.. during an overrule. not an override
Yea I've read the classes and watched the videos.
I forgot about the OpenCloseTransactions thing.
Everything seems to be stable at the moment but I should change that.
”Boost
