Error adding blocks to drawing
Message 1 of 1
Hello!
I'm trying to add a block to a drawing with C#, but it crashes at the following lines:
if (bt.Has("Sensing Unit"))
idBTR = bt["Sensing Unit"];
else
idBTR = doc.Database.Insert("Sensing Unit",db,false);
The fatal error says "eWrongDatabase." Is there any reason why this line would cause that error? How can I check if I have the "right" database before running the check?
Thanks so much for any help!
-Carlos
Replies (0)
