.NET
Distinguished Contributor
SRSDS
Message 1 of 6 (167 Views)
Error Trapping
167 Views, 5 Replies
03-14-2012 01:16 PM
In VB6 I used to use
On Error GoTo My_Error
'Code
   On Error GoTo 0
   Exit Sub
My_Error:
    MsgBox "Error " & Err.Number & " (" & Err.Description & ") on line " & Erl & " in procedure MyProcedure of Module MyModule"
By using this in VB.net it the error is skipped and it jumps to the error routine. Easily added using MZ tools.
The same code doesn't report what line but at least reports an error.
 Using the Try, Catch & Finally method often just crates a fatal error and I have to step through code trying to work out what the problem is.
A big problem is that I have spent a long time creating an application with several reactors. I'm not sure if I will ever figure out why it is creating fatal errors.
Is there some reading material that can help me trap errors or work out if I have not disposed of something that should have been?
MarkPendergraft
Message 2 of 6 (162 Views)
Re: Error Trapping
03-14-2012 01:40 PM in reply to: SRSDS
I've had some fatal errors from using Try/Catch ex as Exception/End Try as well.  However I was able to trap them using the following:
Try
'code.....
Catch
'error message
End Try.
It obviously doesn't provide you with an exception that you can then report to your user, but you should be able to figure out what the error is while debugging and then tell your code to catch it.
-Mark
Valued Mentor
gasty1001
Message 3 of 6 (157 Views)
Re: Error Trapping
03-14-2012 01:49 PM in reply to: SRSDS
This link may help you to understand exceptions: http://msdn.microsoft.com/en-us/library/5b2yeyab(v=vs.100).aspx
Gaston Nunez
Hallex
Message 4 of 6 (154 Views)
Re: Error Trapping
03-14-2012 01:52 PM in reply to: SRSDS
Try in the Visual studio to go to Project --> Properties-->Compile Tab
and set Option Strict to On, then hit F5, you will be see many possible
bad lines in your code before you run it, then revert back Option Stict to Off
and run again
Maybe it will be usefull for you
~'J'~
SRSDS
Message 5 of 6 (120 Views)
Re: Error Trapping
03-15-2012 09:00 AM in reply to: Hallex
It most often never makes it to the catch part . The fatal error is initiated on the bad bit of code.
Something I will have to accept it seems.
That option strict generates a mass of errors. I'll see if I can spot anything unusual there.
Thanks all.
Valued Contributor
Paulio
Message 6 of 6 (112 Views)
Re: Error Trapping
03-15-2012 09:59 AM in reply to: SRSDS
If you're importing Autodesk.AutoCAD.Runtime and you do a "Catch ex as exception" you're only catching the Autodesk.AutoCAD.Runtime exceptions so if you get a System.Exception it will error and not hit the catch.
The Runtime.exception inherits System.exception so catching System.exceptions should get them all.
You are not logged in.
Ask the Community
