.NET
Active Contributor
skeletank
Message 21 of 25 (826 Views)
Re: Error Decrypting Data (Acad 2011)
11-01-2010 08:34 AM in reply to: Aaron.Warnke
Works for me as well.  Thank you very much Gaston! :smileyhappy:
matus.brlit
Message 22 of 25 (790 Views)
11-10-2010 12:12 AM in reply to: hawesan
or you can just catch the exception, i guess
you don't get errors from handled exceptions and you can also test if the problem is because of different application creating the drawing, or because of the potential errors
Valued Mentor
gasty1001
Message 23 of 25 (773 Views)
11-10-2010 11:11 AM in reply to: matus.brlit
Yes, you can trap the COMexception (not a simple Exception), but doing so ( did you?), you still have to set the variable DWGCHECK=2 and try to open the file again in order to get, may be, the drawing opened.
Gaston Nunez
Valued Mentor
gasty1001
Message 24 of 25 (771 Views)
11-10-2010 11:22 AM in reply to: matus.brlit
I think that a better aproach is to set DWGCHECK=2, then try to open the drawing as usual, get the drawing opened and check the DwgFileWasSavedByAutodeskSoftware property in order to take some action.
Gaston Nunez
New Member
Pilz
Message 25 of 25 (419 Views)
02-17-2012 04:52 AM in reply to: *Norman Yuan
Great! This solved my problem also! Many thanks!!
You are not logged in.
Ask the Community
