.NET
*Norman Yuan
Message 11 of 25 (1,925 Views)
Re: Error Decrypting Data (Acad 2011)
04-07-2010 09:03 PM in reply to: hawesan
Do you run the code from an external application (exe) or inside AutoCAD
("netload" it into AutoCAD)?
"harrisonpm" wrote in message news:6369089@discussion.autodesk.com...
Hi Tony
Here is the code that opens the drawing attached
hawesan
Message 12 of 25 (1,925 Views)
04-07-2010 09:47 PM in reply to: hawesan
Hi Norman
The code is run from within autocad (acad 2011).
Thanks Peter
hawesan
Message 13 of 25 (1,925 Views)
04-07-2010 09:51 PM in reply to: hawesan
Hi Tony
This is another drawing (saved as a dwg from microstation) gives the same problem
Peter
hawesan
Message 14 of 25 (1,925 Views)
04-08-2010 05:00 PM in reply to: hawesan
Tony
I have actually fixed this problem, it seems to have been a lisp file that I had in my startup suite contents that caused the error, still not really sure why but my .net macro now works on all drawings it open up. Thanks for your help in trying to solve this problem.
Peter
Active Contributor
skeletank
Message 15 of 25 (1,825 Views)
10-20-2010 12:13 PM in reply to: hawesan
I am running into this same problem.  I tried the COM Interop example that Tony Tanzillo gave but it still throws that error when I try to open it.  My file was generated by a third-party tool as well.
Aaron.Warnke
Message 16 of 25 (1,778 Views)
10-29-2010 11:15 AM in reply to: skeletank
I'm having the same problem too.  Seem to only happen with dwg files created from something other than autodesk products.  Drawings open fine directly through AutoCAD (2011), but noth with vba.  Also works fine with 2010.
Active Contributor
skeletank
Message 17 of 25 (1,776 Views)
10-29-2010 11:30 AM in reply to: Aaron.Warnke
I ended up using a workaround for the problem.  The operation that I needed to do did NOT require opening the drawing so I just opened it using Database.ReadDwgFile.  It didn't throw any exceptions by doing it this way.
Aaron.Warnke
Message 18 of 25 (1,771 Views)
10-29-2010 11:33 AM in reply to: skeletank
Thanks for the quick reply,  but I need to open the drawing. I wonder why it is different between 2010 and 2011?
Valued Mentor
gasty1001
Message 19 of 25 (1,758 Views)
10-31-2010 01:57 PM in reply to: hawesan
This problem is related to the DWGCHECK system variable, set it to 2 , the default is 1, this problem also apears in VBA but with a different error message, something like "Filer error" , but the "solution" is the same set DWGCHECK=2.
Gaston Nunez
Aaron.Warnke
Message 20 of 25 (1,737 Views)
11-01-2010 07:59 AM in reply to: gasty1001
It works!
Thanks alot Gaston!
You are not logged in.
Ask the Community
