.NET
hawesan
Message 1 of 25 (3,139 Views)
Error Decrypting Data (Acad 2011)
3139 Views, 24 Replies
04-06-2010 05:12 PM
I get the following error in vb .net macro :
System.Runtime.InteropServices.COMException was unhandled by user code
ErrorCode=-2145386153
HelpLink="C:\Program Files\Autodesk\ACADM 2011\HELP\OLE_ERR.CHM#-2145386153"
Message="Error Decrypting Data"
Source="AutoCAD"
StackTrace:
at Autodesk.AutoCAD.Interop.AcadDocumentsClass.Open(String Name, Object ReadOnly, Object Password) at dwgdb1.addDrawings(String& typestr) in C:\Users\harrison.pe\Documents\Visual Studio 2008\Projects\GEA_DrawingDB\dwgdb1.vb:line 346 at dwgdb1.CommandButton4_Click(Object eventSender, EventArgs eventArgs) in C:\Users\harrison.pe\Documents\Visual Studio 2008\Projects\GEA_DrawingDB\dwgdb1.vb:line 557 at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
InnerException:
Works fine in Acad 2010 ! see attached image from visual studio debug
System = Windows 7 (64bit) Autocad Mechanical 2011
*Tony Tanzillo
Message 2 of 25 (3,139 Views)
Re: Error Decrypting Data (Acad 2011)
04-06-2010 05:43 PM in reply to: hawesan
Is the drawing encrypted or digitally signed?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6368203@discussion.autodesk.com...
Source="AutoCAD"
StackTrace:
InnerException:
hawesan
Message 3 of 25 (3,139 Views)
04-06-2010 05:56 PM in reply to: hawesan
Tony - Thanks for your reply.
The drawing doesnt appear to be digitaly signed, the digital signature dialog box doesnt open up and I have it set to display in the options, but the drawing has been created in microstation and I get the following message in the command line :
Non Autodesk DWG. This DWG file was saved by a software application that was
not developed or licensed by Autodesk. Autodesk cannot guarantee the
application compatibility or integrity of this file.
*Tony Tanzillo
Message 4 of 25 (3,139 Views)
04-07-2010 06:12 AM in reply to: hawesan
Well, it could be that Mr. Bass has decided to do something
to AutoCAD 2011 that could become a problem for Autodesk.
Can you post the file or email it to me?
wrote in message news:6368195@discussion.autodesk.com...
line :
hawesan
Message 5 of 25 (3,139 Views)
04-07-2010 01:19 PM in reply to: hawesan
Hi Tony, here is the problem dwg file
*Tony Tanzillo
Message 6 of 25 (3,139 Views)
04-07-2010 02:00 PM in reply to: hawesan
This could be an API change.
Can you post the code that opens the document?
wrote in message news:6368978@discussion.autodesk.com...
hawesan
Message 7 of 25 (3,139 Views)
04-07-2010 02:10 PM in reply to: hawesan
Hi Tony
Here is the code that opens the drawing attached
*Tony Tanzillo
Message 8 of 25 (3,139 Views)
04-07-2010 02:46 PM in reply to: hawesan
Try changing the call to open to this:
acadApp.Documents.Open( filename, True, Type.Missing )
wrote in message news:6369089@discussion.autodesk.com...
Hi Tony
hawesan
Message 9 of 25 (3,139 Views)
04-07-2010 03:04 PM in reply to: hawesan
Hi Tony
I still get exactly the same error.
*Tony Tanzillo
Message 10 of 25 (3,139 Views)
04-07-2010 08:58 PM in reply to: hawesan
Do you get the same error with other files, or just
this one?
wrote in message news:6369133@discussion.autodesk.com...
Hi Tony
You are not logged in.
Ask the Community
