• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor
    vince1327
    Erase last object
    164 Views, 13 Replies
    03-20-2012 12:27 PM
    Hey everyone, In AutoCAD, i can type "erase" and then "last" into the commandline and it will automatically select and erase the last object i created. How is this accomplished in C#? I'm generating a polyline to automatically calculate areas, but i would like that polyline to vanish once the area has been measured. Thanks Vince
    Please use plain text.
    Re: Erase last object
    03-20-2012 01:20 PM in reply to: vince1327
    There is a SelectLast option:
    PromptSelectionResult acSSPrompt;
    Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
    acSSPrompt = ed.SelectLast();
    Gaston Nunez
    vince1327
    03-20-2012 01:42 PM in reply to: gasty1001
    Ok that helps, what would i use to delete what i selected with the editor?
    Vince
    03-20-2012 02:22 PM in reply to: vince1327
    You should start a transaction, get the last object (as entity)  erase it (entity.erase), and commit the transaction and that's it. Like this (not tested, and translated from VB)
    [CommandMethod("ELAST")]
    public void EraseObj()
    	Document acDoc = Application.DocumentManager.MdiActiveDocument;
    	Database acCurDb = acDoc.Database;
    	using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) {
    		acSSPrompt = ed.SelectLast;
    		Entity ent;
    		SelectionSet ss = acSSPrompt.Value;
    		if (ss.Count > 0) {
    			ent = acTrans.GetObject(ss.Item(0).ObjectId, OpenMode.ForWrite);
    			ent.Erase();
    		acTrans.Commit();
    Gaston Nunez
    03-20-2012 04:48 PM in reply to: gasty1001
    I have not used it and of course 'not supported' but maybe you can search for
    Autodesk.AutoCAD.Internal.Utils.EntLast();
    and see if people have had success
    You can also find your answers @ TheSwamp
    vince1327
    03-21-2012 05:49 AM in reply to: gasty1001
    Thanks for this sample, i'm having an issue with the line:
     ent = acTrans.GetObject(ss.(0).ObjectId, OpenMode.ForWrite);
    Visual Studio 2010 and AutoCAD 2012 are telling me that there is no definition for ss.item and thus i cannot compile. As i missing  a reference?
    Vince
    using Autodesk.AutoCAD.ApplicationServices;
    using Autodesk.AutoCAD.DatabaseServices;
    using Autodesk.AutoCAD.EditorInput;
    using Autodesk.AutoCAD.Runtime;
    using Autodesk.AutoCAD.Geometry;
    using Autodesk.AutoCAD.Colors;
    vince1327
    03-21-2012 05:49 AM in reply to: jeff
    Thanks jeff, i'll have a look into this as well.
    Cheers
    Vince
    03-21-2012 06:12 AM in reply to: vince1327
    SelectionSet  it's part of the EditorInput, and I see you are "using" it, so I have no idea why VS is telling you that. Any way the correct sintax is : ss(index).ObjectId without a dot after ss.
    Gaston Nunez
    vince1327
    03-21-2012 06:20 AM in reply to: gasty1001
    Ok, so i've got this now:
    Entity ent;
    if (ss.Count > 0)
    ent = acTrans.GetObject(ss(0).ObjectId, OpenMode.ForWrite);
    ent.Erase();
    acTrans.Commit();
    But the error I have is 'ss' is a 'variable' but is used like a 'method'
    03-21-2012 06:25 AM in reply to: vince1327
    My mistake (i'm a vb guy), just change ss(0) by ss[0].
    Gaston Nunez
