.NET
Distinguished Contributor
vince1327
Message 1 of 14 (223 Views)
Erase last object
223 Views, 13 Replies
03-20-2012 12:27 PM
Hey everyone, In AutoCAD, i can type "erase" and then "last" into the commandline and it will automatically select and erase the last object i created. How is this accomplished in C#? I'm generating a polyline to automatically calculate areas, but i would like that polyline to vanish once the area has been measured. Thanks Vince
Valued Mentor
gasty1001
Message 2 of 14 (212 Views)
Re: Erase last object
03-20-2012 01:20 PM in reply to: vince1327
There is a SelectLast option:
PromptSelectionResult acSSPrompt;
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
acSSPrompt = ed.SelectLast();
Gaston Nunez
vince1327
Message 3 of 14 (207 Views)
03-20-2012 01:42 PM in reply to: gasty1001
Ok that helps, what would i use to delete what i selected with the editor?
Vince
Valued Mentor
gasty1001
Message 4 of 14 (201 Views)
03-20-2012 02:22 PM in reply to: vince1327
You should start a transaction, get the last object (as entity)  erase it (entity.erase), and commit the transaction and that's it. Like this (not tested, and translated from VB)
[CommandMethod("ELAST")]
public void EraseObj()
	Document acDoc = Application.DocumentManager.MdiActiveDocument;
	Database acCurDb = acDoc.Database;
	using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) {
		acSSPrompt = ed.SelectLast;
		Entity ent;
		SelectionSet ss = acSSPrompt.Value;
		if (ss.Count > 0) {
			ent = acTrans.GetObject(ss.Item(0).ObjectId, OpenMode.ForWrite);
			ent.Erase();
		acTrans.Commit();
Gaston Nunez
Valued Mentor
jeff
Message 5 of 14 (190 Views)
03-20-2012 04:48 PM in reply to: gasty1001
I have not used it and of course 'not supported' but maybe you can search for
Autodesk.AutoCAD.Internal.Utils.EntLast();
and see if people have had success
You can also find your answers @ TheSwamp
vince1327
Message 6 of 14 (169 Views)
03-21-2012 05:49 AM in reply to: gasty1001
Thanks for this sample, i'm having an issue with the line:
 ent = acTrans.GetObject(ss.(0).ObjectId, OpenMode.ForWrite);
Visual Studio 2010 and AutoCAD 2012 are telling me that there is no definition for ss.item and thus i cannot compile. As i missing  a reference?
Vince
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Colors;
vince1327
Message 7 of 14 (168 Views)
03-21-2012 05:49 AM in reply to: jeff
Thanks jeff, i'll have a look into this as well.
Cheers
Vince
Valued Mentor
gasty1001
Message 8 of 14 (162 Views)
03-21-2012 06:12 AM in reply to: vince1327
SelectionSet  it's part of the EditorInput, and I see you are "using" it, so I have no idea why VS is telling you that. Any way the correct sintax is : ss(index).ObjectId without a dot after ss.
Gaston Nunez
vince1327
Message 9 of 14 (160 Views)
03-21-2012 06:20 AM in reply to: gasty1001
Ok, so i've got this now:
Entity ent;
if (ss.Count > 0)
ent = acTrans.GetObject(ss(0).ObjectId, OpenMode.ForWrite);
ent.Erase();
acTrans.Commit();
But the error I have is 'ss' is a 'variable' but is used like a 'method'
Valued Mentor
gasty1001
Message 10 of 14 (158 Views)
03-21-2012 06:25 AM in reply to: vince1327
My mistake (i'm a vb guy), just change ss(0) by ss[0].
Gaston Nunez
You are not logged in.
Ask the Community
