• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Member
    darpz
    Entity advice
    240 Views, 10 Replies
    02-26-2012 09:44 AM
    Hi, i'm starting to develop a .NET plugin, so i'd like to have some advice from you experts :smileywink:
    I've just to draw some rectangles on a map (a 2D layer) an then set a label that show me the name and then set other "invisible" properties that describe my area.
    I thought to represent this with a region and put a label on it; I'd like that these entities have a kind of relation, like move togheter etc. and finally store into this area some properties, like strings and numbers.
    i have to create a custom entity with C++ or there is some other (easier) way to do this?
    thanks in advance....
    Bye.
    Please use plain text.
    Valued Contributor
    FFlix
    Re: Entity advice
    02-27-2012 05:44 AM in reply to: darpz
    hi
    database services contain a GROUP dbobject, which can take the respective label as name and any entities you want associated with it can be appended (and removed), although they remain individually editable.
    felix
    Distinguished Contributor
    VB_Autocad_guy
    Re: Entity advice
    02-28-2012 01:52 PM in reply to: FFlix
    I don't think you have to use C++, you could use any .NET language.
    Visual Basic, C++, C# and there's some others.
    But if you are learning why not try Visual basic.
    Have fun, the adventure has only begun
     :smileyhappy:
    Valued Mentor
    KerryBrown
    Re: Entity advice
    02-28-2012 03:09 PM in reply to: VB_Autocad_guy
    VB_Autocad_guy
    If the op wants custom objects c++ ARX is the option.
    .NET managed does NOT create custom objects.
    Regards
    class keyThumper<T> : Lazy<T>;      another  Swamper
    I do not endorse the social media app links below:smileyembarrassed:
    dgorsman
    Re: Entity advice
    02-28-2012 03:27 PM in reply to: KerryBrown
    C++ *is* the only way for custom objects, but there may be some other options that are easier to implement and friendlier to other users: static or dynamic (stretchable) block with attributes, grouped entities, either with XDATA or Extension Dictionaries/XRecords both come to mind.
    As I always say, code is the end product, not the start.  There needs to be a lot of prior planning, outlines, object model research, etc. prior to writing a single line of code.
    Adopt. Adapt. Overcome. Or be overcome.
    Valued Mentor
    KerryBrown
    Re: Entity advice
    02-28-2012 04:20 PM in reply to: dgorsman
    :smileyhappy:
    true that !
    VB_Autocad_guy
    Re: Entity advice
    02-28-2012 08:14 PM in reply to: KerryBrown
    Thanks Kerry,
    Custom Objects huh? So you can do that in Arx huh?
    Thanks for clarification.
    Member
    darpz
    Re: Entity advice
    02-29-2012 02:28 AM in reply to: darpz
    Thanks guys, i think i will wait a white before try to create c++ custom object.
    The "Group of Entities" solution seems to be a good choice!
    So i will try to put a region and a label with the name in a group, i have just another question:
    Where can i put the other properties of my object, i'd like to have a group with its (invisible)
    data field like a C# class; I read i can use XData, correct?
    There's a tutorial that explain how to use it?
    Thanks again
    Cheers.
    dp
    Re: Entity advice
    02-29-2012 04:50 AM in reply to: darpz
    the way to create "custom objects" in .NET is the Overrule API
    XData is an easy way to stick some data to entities, but it has limitations (i think there's a maximum size of the XData), it's recomended to use ExtensionDictionary, which is also quite simple
    you have to create the ExtensionDicionary with DBObject.CreateExtensionDicionary() and then add some Xrecords in it
    Valued Mentor
    KerryBrown
    Re: Entity advice
    02-29-2012 04:40 PM in reply to: matus.brlit
    No,  words have meanings.
