.NET
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Entity advice
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, i'm starting to develop a .NET plugin, so i'd like to have some advice from you experts ![]()
I've just to draw some rectangles on a map (a 2D layer) an then set a label that show me the name and then set other "invisible" properties that describe my area.
I thought to represent this with a region and put a label on it; I'd like that these entities have a kind of relation, like move togheter etc. and finally store into this area some properties, like strings and numbers.
i have to create a custom entity with C++ or there is some other (easier) way to do this?
thanks in advance....
Bye.
Re: Entity advice
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hi
database services contain a GROUP dbobject, which can take the respective label as name and any entities you want associated with it can be appended (and removed), although they remain individually editable.
felix
Re: Entity advice
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't think you have to use C++, you could use any .NET language.
Visual Basic, C++, C# and there's some others.
But if you are learning why not try Visual basic.
Have fun, the adventure has only begun
Re: Entity advice
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If the op wants custom objects c++ ARX is the option.
.NET managed does NOT create custom objects.
Regards
class keyThumper<T> : Lazy<T>; another Swamper
I do not endorse the social media app links below![]()
Re: Entity advice
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
C++ *is* the only way for custom objects, but there may be some other options that are easier to implement and friendlier to other users: static or dynamic (stretchable) block with attributes, grouped entities, either with XDATA or Extension Dictionaries/XRecords both come to mind.
As I always say, code is the end product, not the start. There needs to be a lot of prior planning, outlines, object model research, etc. prior to writing a single line of code.
Adopt. Adapt. Overcome. Or be overcome.
Re: Entity advice
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
true that !
Re: Entity advice
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Kerry,
Custom Objects huh? So you can do that in Arx huh?
Thanks for clarification.
Re: Entity advice
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks guys, i think i will wait a white before try to create c++ custom object.
The "Group of Entities" solution seems to be a good choice!
So i will try to put a region and a label with the name in a group, i have just another question:
Where can i put the other properties of my object, i'd like to have a group with its (invisible)
data field like a C# class; I read i can use XData, correct?
There's a tutorial that explain how to use it?
Thanks again
Cheers.
dp
Re: Entity advice
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
the way to create "custom objects" in .NET is the Overrule API
XData is an easy way to stick some data to entities, but it has limitations (i think there's a maximum size of the XData), it's recomended to use ExtensionDictionary, which is also quite simple
you have to create the ExtensionDicionary with DBObject.CreateExtensionDicionary() and then add some Xrecords in it
Re: Entity advice
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
matus.brlit wrote:>>> the way to create "custom objects" in .NET is the Overrule API
No, words have meanings.
